Refrigerators Logo
Posted on Nov 15, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore coldspot refrigerator model #106 RUMBLING!!!
I have a kenmore coldspot refrigerator model #106 60192000 with a manufacture date of 09/00 is making a loud rumbling/vibrating noise. When you turn the temperature dial all the way down to the warmest setting it kicks down and stops rumbling. What is the noise? How do I fix it?
Just started tonight! Please help.
Chris Huff
Level 3:
Top Expert:
  • Kenmore Master 6,289 Answers
  • Posted on Nov 15, 2017
Chris Huff
Kenmore Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2020431
Points
74913
It's the compressor or a fan.
Cheryl Tardiff
Level 1:
New Friend:
  • Contributor 4 Answers
Cheryl Tardiff
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
952
Points
8
Does it have automatic ice cube maker not hooked up to water? If you do make sure thin stainless bar isn't straight down. on the side of ice maker.
4 Related Answers
Michael Anderson
  • 172 Answers
  • Posted on Apr 30, 2008
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck [email protected]
Anonymous
  • 15 Answers
  • Posted on Aug 08, 2009
SOURCE: Kenmore Coldspot Model 106 9557651 stopped cooling
please make sure that the electricity supply to the unit is in order. after that check wether the thermostat is in working order and if the compressor is running. If everything is in order tou have a gas leak and the unit must be charged with gas.
Anonymous
  • 572 Answers
  • Posted on Feb 08, 2010
SOURCE: Kenmore Coldspot model 106 - Snowing in freezer!
its not defrosting. check heater operations. bimetal near heater. check defrost timer
Anonymous
  • Posted on Dec 19, 2010
SOURCE: kenmore coldspot model 106: top freezer leaks
Have you tried adjusting the freezer temperature to a higher level? This worked for my Kenmore. It will take a couple of days to quit leaking.
How much does a kenmore coldspot 106 refrigerator weigh?
No data exists. Ball park figure by dimensions
https://www.google.com/search?q=kenmore+coldspot+106+weight
Weight of French door fridge.: Weight (lbs.) 331 Weight, Shipping 364
1helpful
Question about size of Kenmore Coldspot Refrigerator
What Are Some Specifications of the Kenmore Coldspot ...
https://www.reference.com > World View
The Kenmore Coldspot 106 is a 20.7-cubic foot side-by-side refrigerator with a reverse osmosis Pur water filter, ice maker and digital controls.
11helpful
3answers
2answers
Have kenmore coldspot model # 106 manufactured 08/97 that drain is not operating bottom of freezer ices over no matter what temp.is set at
Need the complete model number for this unit, but I am going to guess that you have a defrost problem with the freezer, more than a drain issue.
2answers
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
