If the paper feed lever is stuck in the up position keeping you from inserting the drawer, try opening the lower panel on the left side where the paper feeds from the tray.
First remove the screw on the right hand side that allows you access to the power cable for the feed unit. Unplug this cable (should have yellow wires). Once this is unplugged the arm should drop back down.
To totally remove the paper feed unit, remove the two screws on the left side and one more on the right hand side that was under the cover as well. This will allow you to remove the paper feed unit to inspect for damage.
Unplugging the unit caused the arm to drop in mine.
Prior to the issue you facing basically ,you check whether u can reattach the arm or you can try to compare with another drawer to figure it out .See anything that broken or crack pieces.Kindly post pic to me ,I'll might help u.Thanks ,pls rate me!!!!
