I've got the Craftsman convertible (2003 25cc, 358.795501).
I've been having problems for a couple months. It will start after about 20 pulls and then only run for a few seconds at high RPM. It takes doing this 2 or 3 times before it will stay running – and then only on choke at max throttle. It's progressively gotten worse over these last few weeks until today when I couldn't get it to stay running more than those few seconds.
I've changed the fuel, cleaned the air filter, even tried taking it apart to see if something is loose – it does seem like something is loose. I can't take it apart enough to find anything that's serviceable (hex wrenches, screws, etc.) It is leaking a little oil.
Thanks! Rob Phx AZ
SOURCE: fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
Go to sears.com then parts store then type in model no. You should find a parts breakdown hopefully that will help.
SOURCE: 25cc Weed Eater
Yes. any 2 cycle oil will do. It is right do not use marine oil it runs alot thicker than 2 cycle oil.
