Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it ...my dishwasher start and why does the "Heated Dry" light keep blinking ...
The
model indicated: MDB5651A does not have display and the error codes are
shown like flashing lights. If that is your model and problem please
just tell me what lights are flashing.
In Maytag with display
instead, the L on display means that the machine is control locked. That
is not an error message, but a code telling that the machine has been
locked by the user (probably by mistake since you are the user).
I quote from Maytag technical documentation:
? If a cycle or option pad is pressed after the controls have been
locked, the indicator light next to lock graphic will flash five
times. On selected models with a countdown display, the display will
flash the symbol "L" simultaneously with lock indicator.
? This option does not lock the door, only the dishwasher controls.
To set :
1. Press the Heated Dry pad for three seconds.
2. An indicator light next to the lock graphic will illuminate when the controls are locked.
To Cancel Control Lock:
2. The indicator light will go off as instructed.
Try pressing the the Heated Dry pad for three seconds. If that doesn't work disconnect power.
Connect back and try again unlock (power off does not remove the lock).
If that still does not work there may be a faulty part. In that case
turn appliance off and give me the full model number.
Start
holding down the Heated Dry pad for three seconds. In normal conditions
that is enough to get rid of the L and of control lock.
When Control Lock is lit, all buttons are disabled. If you press
any pad while your dishwasher is locked, the light flashes
5 times. The dishwasher door can be opened while the
To turn off Lock, press and hold Heated Dry for at least
3 seconds.
that is the fault code indicating the button is stuck. the touchpad must be replaced. the lock light indicated two or more buttons activated at same time
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Try pressing heated wash, heated dry, then heated wash, heated dry. It should reset it. Also try pressing and holding the cancel button for 5 seconds to see if that works if the other doesnt.
I too had the same problem,,and tried it again,,,and it worked for me,,i pushed the button next to the lock light it blinked and i kept holding in the dry button and the lock went off,,,,good luck
