Electric 3/4hp 1800RPM 56C Frame 12 Volts Dc Tefc Leeson  Motor # 108048 Logo
Posted on Sep 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to wire an electric motor - Electric 3/4hp 1800RPM 56C Frame 12 Volts Dc Tefc Leeson Motor # 108048
Anonymous
Level 2:
  • Expert 143 Answers
  • Posted on Sep 20, 2009
Anonymous
Expert
Level 2:
Answers
143
Questions
0
Helped
70956
Points
280
Do not attempt at home unless qualified. Electricity can be fatal
2answers
How to connect a six wire blower motor to a four wire blower motor.
It is not possible to directly connect a six wire blower motor to a four wire blower motor because they have different wiring configurations. However, you may be able to modify the wiring to make it work, but this would require a thorough understanding of electrical circuits and potentially void the warranty of the blower motor.
If you are not familiar with electrical systems and wiring, it is recommended to consult a professional electrician or HVAC technician to ensure safe and proper installation. They will have the necessary knowledge and expertise to assess the situation and provide suitable solutions.
Need a wiring diagram for a Magnetek Century Electric motor (motor # 6-362952-01) which includes the capacitors.
If it was available, it would be in this link.
https://www.google.com/search?q=Magnetek+Century+Electric+motor+6-362952-01+wiring+diagram
Stripping the Search Query right down to the barest, gives good generic advice on motor wiring. I local electric motor outlet would know.
https://www.google.com/search?q=%226-362952-01%22+wiring+diagram
Only the fan climate control is not working. The display climate control is working but only the fan.
That is the heater / AC blower motor ! There are electrical circuits and relays and blower motor resistor , blower motor etc... Electrical testing is the way to diagnose blower motor circuit . Looking at a wiring diagram to see what controls the blower motor on your particular vehicle would be the first step in diagnosing your problem . Do you know how to do automotive electrical testing , how to read or follow a wiring diagram ? Videos on youtube show how to test blower motor and related parts and wiring . Blower Motor and Resistor Diagnostics by Wells
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
How do I reverse a three phase electric motor?
Reversing rotation of 3 phase motors:
CAUTION: Before attempting any repair of electrical equipment verify the power is disconnected to the device.
CAUTION: Three phase motors could potentially be controlled by frequency control systems. It is recommended a trained electrician perform repairs to any electrical system. In particular, consult a trained electrician if the system includes a frequency control system.
Most 3 phase motors can reverse rotation simply by swapping any 2 of the 3 phase wires. A typical 3 phase wiring circuit will include a safety ground wire (usually green) and 3 phase wires, often designated A/B/C, or 1/2/3, or color coded to distinguish each. By swapping the terminal connection of any 2 of the three phase wires, for example, 1 & 2 or 2 & 3 or 1 & 3, but leaving the third phase wire unchanged will reverse the rotation of most motors.
I have old spa motor with Red - low speed, Black - High speed, White - Neutral, Green - ground. New Dayton 5PXG3 motor has only L1, L2 and ground. How do you wire that?
The motor should work if you connect the black wire to L1, white wire to L2 and green wire to ground. The red wire should be cut so the conductor does not extend past the insulation and the end wrapped with electrical tape.This should be correct if the motor is a 120 VAC motor. If the motor is a 240 VAC motor then the white wire is not really neutral. It should be wrapped in both the motor wiring area with black electrical tape and the other end in the timer should also be wrapped with black tape.
If this causes a problem because you now have no low speed for the spa then the only way to get the low speed is to squire a 2 speed motor.
I hope this helps.
Motor growls & low torque. Need a wire diagram to check for proper wiring.
I'm not sure what happened on here, but your problem with a motor is listed under the heading for a 200amp main breaker. What kind of a motor are you talking about? Gas, electric? what brand what model?
Replaced a one speed 230volt 1 phase electric motor with a two speed 230 volt 1 phase electric motor, now have extra wires which color wires do you use or cap??
Look at the old motor and see what the rated rpm was. Next look at the new motor and see if it gives a speed for each wire. If it doesn't give the speed for each wire then look at the rated motor speed. That will be the Hi speed. Hook up the wire that matches the speed of the old motor and cap the other.
17helpful
2answers
Wiring diagram for dayton ac electric motor
i need wiring diagram for a dayton electric motor 4mb22
2answers
ASEA CYLINDA 1200 Dish Washer Electric Motor Wiring Connections
A neighbour happened to call in and popped the right wire in the right place and presto we were in business. Not sure what he did but it worked. thankyou. wal
Nov 15, 2008 • Dishwashers
Top Electric Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you an Electric Tool and Hardware - Other Expert? Answer questions, earn points and help others
