Polaroid flat panel tv will not turn on. the red light is on but will not power up?
You have a blown cap in the power supply it will be puffy on top replace them or have it done
this model as well as other models from poalroid have serveral diferant power supply/main board combos. about in the middle
og the power board if there is a standup diode on a heat sync
. if you have a volt /ohm meter put is on diode check if the diode reads short 0 ohms it needs to be replaced if you don;t have this diode you need a mainboard or complete control box very hard to find any parts for these set try shop jimmy.com we aget a million of these sets at our shop we are the pnly shp thet repairs to componant level// good luck my freind
none of them are puffy on top.
