While replacing the DVDR drive in my e-machines T6520 I accidentally disconnected the wires that go from the front bezel to the motherboard. (I disconnected them at the motherboard, they are still connected at the bezel). I was able to reconnect them so my machine boots up and works properly, except the blue led power light on the front of the unit does not come on at all. There are blue/ white, black/white & red/white paired wires coming from the bezel. Which pair are the wires for the blue LED light, and where does it get plugged in to the motherboard? A photo or diagram would be very helpful.
The LED light for the front needs to have the connectors put in opposite but put with the positive and negative the same way as you insert it. The labels should face inward then outward and put one by one not simultaneously.
Red white is the pair that supplies power it should be 2pin socket on motherboard
