Kicker Solo-Baric L5 Car Subwoofer Logo
Posted on Sep 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you wire L5 to 2 ohm - Kicker Solo-Baric L5 Car Subwoofer
Marco Marquez
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 04, 2023
Marco Marquez
Contributor
Level 1:
Answers
Questions
0
Helped
729
Points
I got two 12-in Solo-Baric L5 dual voice coils how would I wire them up so that they're in series and push out to one channel to a 2400 watt one channel amp how does the wearing go
Anonymous
Level 3:
  • Master 655 Answers
  • Posted on Sep 20, 2009
Anonymous
Master
Level 3:
Answers
655
Questions
0
Helped
314466
Points
2081
Hello lholt07,
If the L5 has 4 ohm voice coils, you simply wire both voice coils in parallel, both marked and unmarked positive terminals together and to the amp and likewise with the negative terminals. If the L5 has 2 ohm voice coils, it cannot be wired to 2 ohms.
Hope this helps.
Hohow do you wire a 10 inch kicker L5 to aMTX 421
I take it s dual coil sub at 4 ohm ? Bridge the coils on sub and wire straight to your amp it's a 2 ohm imp amp , check crutch field wiring diagram if your not sure or better still get a professional to connect it for you.
How do I wire kicker l5 dual 4 ohm with school in
You need to wire your sub to match your amps impedance check crutch fields website for wiring instructions.
WHATS THE BEST WAY TO WIRE 2 DUAL 2 OHM L5 15
Crutchfield is always handy for a wiring diagram.
1helpful
Would a 10ZX750.1 amp be alright on a Single Solobaric L5 10" inch in a ported box???
yes, the 10ZX750.1 is capable of running two L5's at two ohms in either a ported or sealed box. Just be sure to wire it up to suit your needs correctly (if you need to know how i can help) and make sure that your box dimensions match what kicker specify. the L5 is actually one of the subs that kicker reccommend for that amp.
Hope I helped , and please dont forget to rate.
cheers
How do i hook up kicker solo baric in the box
Option 1 (parallel/parallel) = 0.5 ohm load
Voice coils wired in parallel, speakers wired in parallel
Recommended Amplifier: Stable at 1/2 ohm mono 2_2ohm_dvc_05ohm.gif
Option 2 (series/parallel) = 2 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_2ohm_dvc_2ohm.gif
Option 3 (series) = 8 ohm load
All voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif Option 1 (parallel/parallel) = 1 ohm load
Recommended Amplifier: Stable at 1 ohm mono 2_4ohm_dvc_1ohm.gif
Option 2 (series/parallel) = 4 ohm load
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif
How do i install my L5 solo barics to a 2 channel amp if there is only one connection on the enclosure next to the vent? If I bridge the amp to 1x1000W will the power distribute evenly between both...
Option 1 (parallel) = 2 ohm load
Speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_4ohm_svc_2ohm.gif
Option 2 (series) = 8 ohm load
Speakers wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_svc_8ohm.gif
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif Option 1 (parallel/parallel) = 0.5 ohm load
1helpful
Amp cuts out but not in to protection
definately wireing wrong some amps dont like the 1.33 are you testing your wiring jobs with a volt meter! just set it to the resistance/ohms and verify that you are actually getting 1.33 or the ohms you want!
2answers
Do I wire 4 ohm voice coils in series or parallel to get a 2 ohm circut?
Basically, it would be the amp that would dictate whether series or parallel. If the amp is rated at X watts @ 2 ohms, then the speakers could be wired in parallel. If however the amp is rated at so many watts in 4 ohms, then it would be safer to wire the speakers in series to achieve 8 ohms.
If two 4 ohms speakers are wired in parallel, the end result is a 2 ohm load. If the amp is rated at 4 ohms, and presented with a 2 ohms load, possibilities are:
  • autoprotect would kick in often;
  • burn the output transistors of the amp.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
2helpful
3answers
Kicker solobaric l5 12''
how to wire a kicker solo baric l5 12'' 4ohm down 2 and 1 ohm
Top Kicker Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
