Last night we came home and the GA Power truck was in our lawn, working on a transformer. all power to tyhe house was off, after power was restore, none of our electronics would work, we noticed a burnt smell on the circuit protector, unplugged from protector and plugged into outlet. No power to TV, the wall outlet its working propertley, (checked with tester) still TV will not come on. Is there an internal reset button on this unit? if not, what else can I do? Thanks Tony
SOURCE: Sharp 27N-S300 TV problems
This could be several things, but most likely a burned loose resistor or bad solder joint. All of which causes an inoperative power supply with the result of having a "dead" set. It would have to be checked out to find the problem. Stargazer
SOURCE: Sharp R-1850A Mocrowave Convection - No power
Chances are if the internal fuse and magnetron thermostat are good, then you have a circuit board that needs repair.
You can probably find exploded views at the Sears parts site. If you find a bad thermostat, the best place to order Sharp parts is Tritronics.
We regularly repair these control panels for customers nationwide (RV owners & dealers, too) with our guaranteed $39.95 service.
Feel free to contact me directly for more information & help.
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: LC-65D64U Sharp Aquos
Call sharp back again and tell them you first want to register for aquos advantage program, which is free. By doing that your service will go much quicker with them. You then tell them that you want to get set up for service. They will have one of their authorized professionals come and fix your tv in a matter of days. If their tech cannot fix it, they will replace your tv free of charge as long as you are within your warranty.
SOURCE: shut off itself
sounds like you might have an auto overvoltage shutdown circuit kicking in. The hivoltage goes to high and the monitoring circuit auto shuts down. More than likely trouble is in hivoltage circuitry. If you have a transformer that will allow you to bring up the set slowly without shutting down and you can look to see what's happening.
SOURCE: Remote control for Sharp TV
Hold down the tamper proof button on your remote for up to ten
seconds, until the tamper proof light will blink and light
will go off. This will turn off the Tamper Proof button.
Let me know how it goes.
i would remove back of unit to look at the fuse.if its bad replace it one time with exact value.please let me know how things went
