It basically means the battery has outlived it's use and can no longer hold a charge. Even though the charger is hooked up you will still need a new battery to get away from this problem. Once the new battery is installed and charged this error should disappear. Hope this helps.
Thanks a lot for your help! I've taken out the battery and now it works!!! Thank you!!!
How old is the battery? Try this...remove battery and see if it will run from the AC charger alone. If so, you probably just sorted out the problem.
