Washing Machines Logo
Anonymous Posted on Sep 19, 2009
Whirlpool AWM 045-1000 washing machine has suddenly stopped working and warning light "WATER STOP" has come on. Any ideas for a fix?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1010
Points
Whirlpool AWM 1203. Washing machine keeps stopping.
Question edited for clarity, add maker, toss in some CAPS.
Question moved to maker category.
Likely needs a new controller board.
https://www.google.com/search?q=whirlpool+awm+1203+stops+at+end+of+cycle
We have whirlpool awm 029, that keeps stopping mid cycle, will restart when turn on / off switch
No cold water will stop it b4 rinse change water valve or turn cold water on all the way
1helpful
How do I fix a whirlpool washing machine with the 'door locked' light blinking?
The door lock needs to be replaced. I would recommend using a technician to replace the part just to be on he safe side.
Whirlpool awm 6120. does not work and light are blinking.
Hard to know without more information, have you checked pump filter in flap at bottom of machine or tilt forward if you get a little bit of water you have a leak inside and a sensor will stop machine, if it will run after tilting machine that would confirm your problem.
AWM5104/1 Front Load Washer: Whirlpool AWM 5104 - The machine turns on and the ...
May be the belt at the back of the machine is loosen or cut off kindly check it and replace the belt
2answers
Whirlpool Washing Machine AWM 029 is not draining
Hi.
I assume you have checked to see if the pump is working,
Select drain and spin, if water does not go away, then you have a pump problem, which will stop the programme completing.
Please leave feedback.
Thanks
Washing cycle starts and takes hours even for short cycle.
Try checking for good water supply.
Pull out detergent tray and check for good water supply during filling.
if poor filling-
Try checking the hoses.
Turn taps off, disconnect from machine, place hose end in sink, turn tap on and check for good water flow.
if the hose has a red indicator in the side of the hose (end which is fitted to the tap) - Red indicator is a failed hose.(for models with Water Stop hose type "B")
Whirlpool washing machine Model AWM 5104/5
the despencer has a motor on it are a water valve that puts the water into the right despencer at the right time to make it work look under the top if its a water valve type needs new valve
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
