However, any third party software that was on the disc will not be available. (The OEM copy of PaperPort SE with OCR was on the CD for Windows systems.) You'll need the original disc or to replace the software with the full version if you use it. (You would need OmniPage to replace PaperPort SE with OCR. PaperPort and PaperPort Pro do not include OCR capabilities.) There are other programs that do this as well.
I hope this helps.
Cindy Wells (Brother does not offer replacement install CDs for printers.)
Did you checked if your printer is compatible with windows 7?
Here go to this site to check if your model is one of the compatible to windows 7
http://www.brother-usa.com/lp/windows7compatibility.aspx
if you find your printer there and it is compatible with windows 7 you can download the driver in the BROTHER SOLUTION CENTER column on that webpage/
Goodluck, Hope I hep. Please rate my solution thanks.
faq000559_002
When I try to OCR into WordPad using the ScanSoft® PaperPort® SE with
OCR or the Brother ControlCenter3, the text comes out as gibberish.
This started after I installed Windows® XP Service Pack 2 (SP2). Why and
what should I do?
faq002613_000
When I try to scan to OCR I get an error message saying "This feature
is not available because there is no OCR Software installed".
faq002561_000
How do I configure or change the settings of the ControlCenter 2 or 3 scanning options?
faq000562_002
When scanning to OCR from Brother Control Center3, the OCR
application doesn't launch. I have Windows® XP Service Pack 2 (SP2)
installed. What should I do?
faq000563_002
When scanning to OCR from PaperPort® SE, the following error message
appears: "System error incurred in external ink module EZText.g32. The
OCR server is unable to process the document". I have Windows® XP
Service Pack 2 (SP2) installed. What should I do?
The only real way to make this printer wireless, is to connect its ethernet port to a wireless router and via the router, send jobs to the printer wirelessly. hope this helps. Cost is about $60-$70 for the router.
Run the Brother Control Center. Click Device settings. Click where it says Inklevel.
A simpler way is Start-->All Programs-->Brother--> ...-->Status Monitor.
An icon will lodge itself on the tray (a printer). When icon is clicked on, the inklevels will show.
