Question about Faberware FCP240 Coffee Maker
Need directions for the Micro-Perk microwave coffee brewer
I got a micro-Perk coffee brewer but had no instruction. Can anyone who has one tell how to make a cup of coffee in this microwave pot?
I recently bought a microwave coffe maker and it also has no instructions,,, help its from a company called colony...
Posted on Jan 18, 2011
Fill the pot with water to the lower edge of the Micro_Perk ban. Add 1 scoop of coffee and microwave on high for 8 to 10 minutes. This worked perfectly for me.
Posted on Sep 14, 2012
    Scholar:
  • 176 Answers
Email me for instructions. callahanronald@att.net bobbyone
Posted on Aug 11, 2010
SOURCE:
Hello. Bunn coffeemaker VPR Series. When water is poured in coffee starts to make. Carafe gets about 1/3 full and then just drips through filter for about 5 minutes. Never makes full pot.
VPS/VPR are pour over brewers. Like the 12 cup brewers you find at home, they need to be filled with 12 cups of water (a full pot), heated and then peculated over the coffee grounds and collected in a decanter.
BUT there is one main difference! The VPR and similar COMMERCIAL coffee machines are quick brewers. They usually have a pre-heated pot of water stored inside the machine.
* VPR's and similar machines REQUIRE a pre-fill and heating period prior to brewing. This means it's sitting on a level table and filled with water until water sprays from the brew head. At this point the unit is plugged in and the heater is turned on (there may be some water discharge from brew head as the water expands). Ready light will come on in about 15 mins.
* To Brew; Place coffee grounds in filter, place in funnel and brew head, clean empty decanter under funnel, slowly pour one full decanter of water (cold or hot) into brew tray. Do not overflow tray. Allow water level to sink before adding more water. Only fill with one pot as an equal amount will come out the brew head and funnel.
* Make sure the decanters are all the same size. do not mix a 12 cup pot with a 10 cup pot. One will over fill and the other will under fill. Make sure they match (in cup volume) FYI; Thermo Air pump pots are usually bigger than one pot. Typical filling only to 3/4th of the container. (I think most are in 2.5 to 3 liter sizes)
* If your not getting a full pot then the brewer was partially empty. The second brew (if done within the next hour) should come out full.
* If your still not getting a full pot then the water is leaking or is boiling off. Does it always steam from the top? Thermostat is shorted. Unplug the brewer and call vendor for service.
* Final; If your unplugging when not in use. Then follow the Pre-heat instructions mentioned above prior to plugging the brewer back in. If the tank has been emptied at night or dried up after an idle week. Then there is a chance you may over heat and blow the thermal fuse. Or at best have a half pot short brew as the water dried up.
* Note leaving the brewer plugged in without brewing daily is not a good idea. The water evaporates and eventually drys out the pot. Takes about 1-2 weeks but it does blow the fuse(s) and the unit will need service.
* Final; Follow the Bunn set up and care instructions (manuals from Bunn.com for down loading. *FREE*)
Aloha, ukeboy57
Jul 20, 2017 | Bunn Coffee Makers & Espresso Machines
Replacement 10 cup glass coffee pot
  • Items found similar to "GEMCO 10 Cup Glass Replacement ... www.ebay.ca/sch/sis.html?_nkw=GEMCO 10 Cup Glass Replacement Coffee... Items found similar to "GEMCO 10 Cup Glass Replacement Coffee Maker Carafe Decanter"
  • Items found similar to "BUNN Black Coffee Pot Carafe 10 ... www.ebay.ca/sch/sis.html?_nkw=BUNN Black Coffee Pot Carafe 10 Cup... Please enter a minimum and/or maximum price before continuing. C $ Enter minimum price to C $ Enter maximum price ...
  • One All 10 Cup Glass Eurostyle Universal Replacement ... www.amazon.ca/Glass-Eurostyle-Universal-Replacement-Carafe/dp/...
    • 4.7/5
    • 7 REVIEWS
    • ONE-ALL
    One All 10 Cup Glass Eurostyle Universal Replacement Carafe, Black: Amazon.ca: Home & Kitchen ... This replacement pot fits perfectly with my Braun coffee maker, ...
  • Bunn 10 Cup Replacement Glass Coffee Maker ... - ebay.com www.ebay.com > ... > Coffee & Tea Makers > Replacement Parts & Accs
    • SELLER 100.0% POSITIVE
    • KNIGHTDALE, NORTH CAROLINA
    BUNN 10 Cup REPLACEMENT GLASS COFFEE MAKER CARAFE DECANTER POT Black in Home & Garden, Kitchen, Dining & Bar, Small Kitchen Appliances ' eBay
  • images of Replacement 10 cup glass coffee pot bing.com/images 7f4o0&w=143&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">c03o0&w=148&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">0e6o0&w=113&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">3c4o0&w=113&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2"> See more images of Replacement 10 cup glass coffee pot
  • MELITTA REPLACEMENT GLASS COFFEE POT CARAFE 10 CUP ... www.ebay.com/sch/sis.html?_nkw=MELITTA+REPLACEMENT+GLASS+COFFEE... Find best value and selection for your MELITTA REPLACEMENT GLASS COFFEE POT CARAFE 10 CUP MINT search on eBay. World's leading marketplace.
  • Replacement 10 cup glass coffee pot - Fixya www.fixya.com > Forum > Coffee Makers & Espresso... Replacement 10 cup glass coffee pot - Coffee Makers & Espresso question
  • REPLACEMENT-Coffee-Maker-GLASS-POT-Mr-Coffee-10-12-cup ... www.ebay.com/sch/sis.html?_nkw=REPLACEMENT-Coffee-Maker-GLASS-POT... Items found similar to "REPLACEMENT-Coffee-Maker-GLASS-POT-Mr-Coffee-10-12-cup-"
  • Amazon.com: Medelco 10 Cup Glass Eurostyle Universal ... www.amazon.com > ... > Coffee Machine Accessories > Coffeemaker Pots > Fits my Braun 10-cup coffee maker perfectly. ... Medelco Glass Eurostyle Universal Replacement Carafe - Black, 12 Cup 3.5 out of 5 stars 109. ...
  • Cuisinart® 12-Cup Replacement Carafe in Black ... www.bedbathandbeyond.ca/store/product/cuisinart-reg-12-cup...
    • $34.99
    ... > Cuisinart® 12-Cup Replacement Carafe in Black ... 12-Cup Programmable Coffee Maker in ... original glass coffee pot and the replacement pot fits ...
  • One All Universal 10-Cup Eurostyle Glass Replacement ... www.walmart.com > ... > Kitchen Appliances > Coffee & Espresso Makers
    • 4/5
    • 15 RATINGS
    • $7.84
    • IN STOCK
    Buy One All Universal 10-Cup Eurostyle Glass Replacement Carafe, Black at Walmart ... 10-Cup Eurostyle Glass Replacement Carafe, ... Cup Glass Coffee Replacement ...
  • Mar 10, 2016 | Coffee Makers & Espresso Machines
    How to activate a 10 cup bunn coffee brewer model nhb?
    I don't understand the question, but here is a try.
    1 - put in two pots of water.
    2 - put in third pot, the water should start coming out
    Allow the water to heat (thirty minutes) then put coffee in filter housing, put in one pot of water, put empty pot on warmer, close lid, wait for brew cycle, enjoy coffee.
    Feb 27, 2015 | Bunn 10 Cup Home Coffee Brewer
    Cant start the coffee
    VPS/VPR (VP17-3 are the same except it has 3 lower warmers) are pour over brewers. Like the 12 cup brewers you find at home, they need to be filled with 12 cups of water (a full pot), heated and then peculated over the coffee grounds and collected in a decanter.
    Aloha, ukeboy57
    Mar 28, 2014 | Bunn VP17-3 Coffee Maker
    Will not percolate. Water is poured, it heats up, no coffee brew
    Bunn Home brewers don't perculate. They work the same way that commercial brewers do. Fillit with water, let it heat for about 20 minutes, then put your filter and coffee grounds in the funnel, pour a pot of water into the machine, put the pot on the warmer, and let the water run through. Then enjoy a nice hot cup of coffee.
    Apr 12, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
    My Farberware coffee maker starting making a high
    Hi Farberware China pots and USA pots perk super fast. That is what making the racket. It will stop when the coffee is ready. bobbyone
    Sep 21, 2009 | Faberware 2-8 Cup Percolator
    Bunn GRX-B 10 cup coffee brewer kicks breaker when we turn it on
    If you just bought this brewer, ask your retailer if they will replace it. if not, you can get ahold of the bunn warranty department in your country. they will give you instructions on getting a replacement. This brewer has a dead short in it.
    Jan 15, 2009 | Bunn GRX-B Original 10-Cup Home Coffee...
    Tim Horton's home brewer Bunn coffee maker
    My Tim Hortons coffee pot leake water out the sides when I add water to make more coffee. What should I do ? I like the coffee maker it makes great coffee,
    Jan 11, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
    Farberware 4 and 12 cup percolators stopped making good coffee
    I thoroughly cleaned my 4-cup percolator by brewing a couple of pots of plain white vinegar and scrubbing the build-up from the bottom of the pot (and running a couple of plain water brews through the pot after all the cleaning). The percolator now brews hot, strong coffee again!
    Nov 05, 2008 | Coffee Makers & Espresso Machines
    Faberware FCP240 Coffee Maker Logo
    2,942 people viewed this question
    Top Faberware Coffee Makers & Espresso Machines Experts
    Bob Janelli
    Level 1 Expert
    ellenskitche
    Kolbrun...
    Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
