Please add a comment and say which type, and model water heater you have. Look at label on side of tank. If you have electronic control, please describe the control. This information will let expert access manual and possibly write best solution for your situation.
If you have tankless water heater, read manual, or contact Rheem or qualified service technician.
Add a comment for more free help. Also take advantage of fixya expert assistance live. For a price, expert works with you while you work on water heater or any do-it-yourself project. Fixya is always less expensive than a service call.
Please check if the clean light is blinking 7 times. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry.
If this doesn’t work then it’s an issue with the heater circuit, door switch, wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. If heater is fine then make sure water pressure is optimum and fill valve is working fine.
if both heater hoses going into the fire wall are hot,remove the heater control assembly from dash and make sure cable is connected and do the same under the hood where one heater hose has a valve connected to it,
Question not solution. Help same problem. Heater control panel goes blank and heater and air nothing works. They have had it at shop for 3 days and no answer. Help please.
You Have a bad thermocouple. Follow blue word manual for your manual. It part 24_1. Please hit accept, this is how we get paid. If you need more information Please post back
