Cars & Trucks Logo
Anonymous Posted on Sep 19, 2009
05 5.7 hemi burning 1 qt every 700 miles
05 dodge ram 2500 5.7 hemi burns about 1 quart oil every 700 miles and makes bad knocking sound on start up for about 5 min
  • 1 more comment
  • Anonymous Sep 19, 2009
    normal wear wont fix it been to dealer 4 times now even tryed to get chrysler big wigs involved wont help
    52,000 miles still have 18,000 on warranty but they wont fix it
  • Anonymous May 11, 2010
    Some of these engines are prone to failing oil pumps, What are your gages saying?
Anonymous
Level 3:
Brigadier General:
  • Master 7,353 Answers
  • Posted on Sep 19, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
7353
Questions
Helped
2486348
Points
23804
Does not sound good. how many miles on engine? knocking may be piston slap if it goes away hot. may be engine replacement time.
Testimonial: "thanks for help "
ROB
Level 3:
  • Master 858 Answers
ROB
Master
Level 3:
Answers
858
Questions
0
Helped
328626
Points
2471
Rings & bearings & oil pump need urgent attention!
Cheers Rob
  • ROB Sep 19, 2009
    Go to your local government rep! about the warrantee not being honoured!
    Cheers Rob
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 11, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1589
Points
My hemi is doing it too, it is weak valve springs..
Theres a knocking /ticking sound on right side of 04 ram 1500
If you have not been too good about doing oil changes clogged lifters is very possible. There are many products to flush your oil, but what I prefer is to change your oil and filter , put in 1 quart of marvel mystery oil in place of one qt of oil, run for about 100 miles then change oil and filter again
2helpful
I have a 2008 a4 audi, it uses 1 qt of oil between changes, is this normal
it is within factory specs to burn more than a quart of oil within 2500 miles it is also common with oil changes are done at small and quick oil change places that the oil is not filled to the max level making it look like it burns more than it does and not using synthetic oil as required asl makes a difference
I have a 03 Dodge Ram 2500 Hemi 4X4 that is making a very loud knocking sound in the frontend when I turn left, or right.
check the cv axles at the front differential. inner joints get loose on the splines and cause a knocking noise.
2004 Doge Ram 2500 5.7 Hemi 190K mile had oil pressure gauge drop to ZERO and check gauges light come on and engine shut down.. Check oil 1 guart low, add oil. let cool. crank up, good gauges drove home 45...
If the valve lifters are quiet you most likely have oil pressure even with gauge showing "0".Sounds like the oil pressure switch going bad.I would try that first.
2helpful
2answers
How much oil usage is normal?
1 quart every 2000 miles. Not all cars are created equal. The same model may burn alot less or even more.
1helpful
I have a 2006 Dodge Ram 2500 Diesel (no owners
I don't have a owners maual either but I beleive its 10 liters.Use 15w40 ams oil with ams oil filter.7500-10000 miles for filter changes and 20000 miles between oil changes
2004 ram 1500 with 5.7 hemi using 1 quart every 3,000 miles
Slide a large piece of cardboard under the truck after driving for ten minutes note in which area directly above the spot on the cardboard the oil is coming from then get under the vehicle with a drop light to look for the origin of the leak, if no leak is detected then it may be the engine is burning oil this could either be valve stem seals or broke or worn oil rings.
Engine problems
knocking sound all the time?
when i blew the motor in my car it was pumping oil knocked real bad..
its on its last leg
06 dodge ram hemi engine knock at idle from bottom of engine
Sometimes a valve lifter will stick and cause a ticking it is possible that a valve lifter has lost its prime or it might be that the oil is too thin. Wthout more info my bet would be a lifter
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
