Any ideas on what could be causing the power board to blow?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
SOURCE: lg led tv backlight
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
SOURCE: How can I get my backlights to work on Samsung LCD tv
If your not a TV Engineer , get one to look at it , as you may keep changing the incorrect part.
As far as audio is OK; the main digital board works perfectly. Check the sustain boards. Cannot predict which one has the fault. you have to check and find it.
If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma TVd are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
The LED backlight driver controls the operation of the white light. It may be incorporated in the main board or the power supply board. It can also be a stand-alone board. Depends on the model. You can find the parts you need from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
