Discussion on the internet suggests it may not be possible.
http://www.rootschat.com/forum/index.php?topic=585866.0
Maybe an old computer with an older version of Windows can be found to use it if your old computer is no longer available. This is unfortunately not what you would prefer to hear. It sounds like all the old data might need to be typed into a different genealogy program.
SOURCE: My windows XP home edition wont find my CD drive
it says auto on all three and then when tries to boot cannot find them?
SOURCE: Broaderbund Version 6 Family Tree Maker
Hi madelyn evan,
Version 6 Family Tree Maker is designed to be used with Windows 95 / 98 , therefore in order to use it in Vista you must run your program using Compatinity Mode --> Install your software--> Go to your Desktop --> Right click on the program icon--> properties-->Compatibility--> select one of the versions above
I hope this helps. If so, please take a moment to accept and rate my solution accordingly
SOURCE: HP iPAQ 2215 sync problems with Vista and Windows Mobile 6.1
I've decided to get a smartphone with Windows Mobile 6.1, so this issue has been "solved"
SOURCE: lost cd drive - computer does not recognize any cd
If the cd drive is actually running, but you are not able to access the information on the cd, check to see that the drive appears in windows explorer.
If it does appear, make sure you are current with your optional hardware updates at windows update, then take a look in the Device manager, right click the name of your cd drive, be sure it is enabled, and use the built in troubleshooter to attempt to fix it. This will help you to determine if you are in need of an updated driver for your cd drive, or whether the drive itself has failed.
Here is a link to an excellent Driver update tutorial if that is the problem....http://www.bleepingcomputer.com/tutorials/tutorial119.html
If you are current with drivers for your machine, and the Device manager shows the drive is working correctly, please report back with you OS and the particulars of any error messages you receive when inserting cds and attempting to read/play them. Thanks.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
SOURCE: Lost software CD for Kodak easyshare C633!
follow the link and select your windows version.
http://wwwcaen.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=10/3905/6839/9637/9640&product=EKN032552
