I have a Relic Wet gunmetal watch with a bracelet band. I am limited to the adjustments-1 less link is too tight and the way the watch band is now it's too big. I need a 1/2 link adjustment. I called Relic and was told that all their links are the same size as what I have. Is there somewhere I can buy a specialty Relic link that would be the same color as the rest of the band?
No but if this is a mens watch there might be a micro adjustment on the clasp. To adjust press the pin in the clasp and move the pin in or out depending on the position of the pin to make loose or tight.
Testimonial: "looks like you were right!"
You can pres the pin and can move pin out or in according to situation.
http://www.procuffs.com/Gunmetal-USB-8Gb-Cufflinks-p/pc91.htm
this is a men's watch and it looks like each side of the clasp can move inwards. Can I just use a push pin to loosen this pin (that's what I use on the link pins)?
