Boating Logo
Anonymous Posted on Sep 18, 2009
My Polaris freedom(jet ski) starts and runs good
Jet ski starts well runs for about 30 mins then cuts off.then you have to wait 30 mins before it will start back.it spins but does not start for about 15 mins please help me 2004 polaris freedom jet ski
  • Anonymous May 27, 2010
    i got the problem it was the start/stop switch that was messing around.thanks for all you help!!!!!!!!
Bill Linda Rivard
Level 2:
  • Expert 197 Answers
  • Posted on Nov 14, 2009
Bill Linda Rivard
Expert
Level 2:
Answers
197
Questions
0
Helped
191425
Points
477
Replace exhuast temp sensor.
Anonymous
Level 2:
Sniper:
  • Expert 53 Answers
  • Posted on Nov 03, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
53
Questions
Helped
57640
Points
126
Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local dealer. I know all these are expensive but if your going to be a polaris tech you will always need them. Troubleshooting (1) check compression. Look at your Clymer manual for specific psi.all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark, fuel is the problem nine
times out of ten.Ethanol gas is proven to stay stable in fuel systems for only 30 days in 90 + degree heat. Drain gas tank,clean fuel lines replace and replace all fuel filters. Polaris has a gravity filter under seat, clean it. Finally replace spark plugs, I know spark plugs probably don't look bad but this is a C.D.ignition. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive. Test drive polaris, if the problem is still there then there is further steps to take. If your polaris is fuel injected. Pull out your clymer manual. what is great about the Clymer Manual for Novice techs is it gives detailed info on your polaris. Troubleshooting tips and teaches you how your polaris works. If its carburetor then you should clean carburetors. Inside the carbs is another filter that needs to be cleaned. Its not difficult you just make sure you put everything back in proper order. take pictures if you need to.
Jet ski is "hard stopping"
Any motor that runs and then develops sudden stopping symptoms gives me suspicions of fuel delivery problems.
I'm not familiar with your machine, but I would be looking at the fuel filter as probably plugged up.
Wild guess, but sometimes I luck out.
Cheerfuls.
I have a 1994 Polaris jet ski slt 750 that will start up when it's out of the water but when I put it in the water it won't start. It just started doing this. I had the battery checked and was told it was...
You are deal with moisture corrosion in your carburetor. Take the carb off and clean it paying attention to the corrosion on the rubber tipped needle. Also open your electronics box and make sure that it is dry.
2helpful
2answers
Does not seem to be getting gas
try cleaning the pilot jet and the main jet thats all i think of i know that worked for my dirt bike but i dont know for a jet ski but its worth a try
2answers
Jet ski will not run at full throttle
Check for holes in the diaphram the pulses the needle and seat in the carb.
Jet Ski Will not start when cold
If the teeter/totter needles are gummy or covered with moisture corrosion it could be the reason the machine is so hard to start. When storing the jet ski's syphon all the gas out and burn it in your car or truck. Even if you stabilize it it wont be good fuel in the spring. Your plastic tank will not rust so remove the fuel. You may be able to clean them up by running a tank of Chevron Techron through them. Before riding we charge are batteries and start are jet ski's on the trailer/lift before dropping in the lake. This saves the battery. It takes more juice to start the boat in the water.
No Spark to a 1994-1995 Polaris SL Jet ski
first have you done what is necessary for that such as draining the oil (unless it's a two stroke) draining the gas and refiling it with fresh gas and a couple bottles of gas line antifreeze (it sucks up water) ... for the electrical parts ... spray them with wd40... that will force out any moisture at all and oil does not conduct electricity.
Top Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Boating Expert? Answer questions, earn points and help others
