Hi Loshi-
I found this link.
https://help.brother-usa.com/app/answers/list/st/5/kw/threading%20problems/p/9203/page/1
How to thread the upper part of the machine - Video Included
Follow the steps below to thread the machine - Click here for video instructions. 1. Turn the machine on. 2...
I also found this youtube video link.
https://video.search.yahoo.com/search/video;_ylt=AwrC5pkK_O9d2X4AHlb7w8QF;_ylu=X3oDMTBncGdyMzQ0BHNlYwNzZWFyY2gEdnRpZAM-;_ylc=X1MDOTY3ODEzMDcEX3IDMgRhY3RuA2NsawRjc3JjcHZpZANaOV9SVGpFd0xqRXlpaEVKWGFfVmpnRm5NVGd4TGdBQUFBQWZsVGt2BGZyA3lmcC10LXMEZnIyA3NhLWdwBGdwcmlkA1lzQVdEbUN5UTFTNXdXUWFCc3VhdEEEbl9yc2x0AzYwBG5fc3VnZwMzBG9yaWdpbgN2aWRlby5zZWFyY2gueWFob28uY29tBHBvcwMwBHBxc3RyAwRwcXN0cmwDBHFzdHJsAzM0BHF1ZXJ5A2Jyb3RoZXIlMjBzZTYyNSUyMHNld2luZyUyMG1hY2hpbmUEdF9zdG1wAzE1NzYwMDkxNzU-?p=brother+se625+sewing+machine&ei=UTF-8&fr2=p%3As%2Cv%3Av%2Cm%3Asa&fr=yfp-t-s
Hope these help.
SOURCE: When I sew or embroider with my husqvarna designer
Your check spring or check spring sensor need to be replaced, take it to a Husqvarna repair shop, there is nothing you can do yourself..
SOURCE: I keep getting the error message
the problem of your machine is your bobbin, you should adjust it.
SOURCE: I tried everything i have a Brother SE-400. For
Is your thread old? I had some thread that I was trying to use up and my machine decided that it did not like it all of a sudden. Maybe, unplug and totally rethread with a fresh needle. Sometimes, the little buggers get particular. Hope it is something this simple. Good luck
SOURCE: Artista 180 - I keep
There are a number of possible reasons for this, but, assuming the thread hasn't actually broken (!), it may well be that the upper thread sensor flag has come off the check spring - this is something I see fairly regularly and is frequently the result of people pulling the upper thread 'backwards' out of the machine a bit too quickly, rather than cutting it off at the spool and drawing it through the machine in the correct direction. It's a bit fiddly and very difficult to explain how to check this, without taking all the covers off. However .... if you take the head cover off (single screw) and look carefully at the bottom of the metal takeup lever cover you will see a large slotted screw with a spring wound around it - this is the check spring. The end of the check spring pokes-out behind the takeup lever cover and the thread goes through a loop in its end when you thread the machine up. Thread the machine up as far as the takeup lever, take hold of both ends of the thread and gently raise it - you should see the check spring move upwards. Now, look very carefully at the part of the spring between the big coil around the screw and the loop where the thread passes-through ... there should be a black plastic part attached from the other side of the takeup mechanism (you cant get at this without taking the front cover off !). If it's not attached, you can very very carefully wiggle the spring and sensor flag back so that the spring sits in the slotted part of the sensor flag (either that or take it to your Bernina service agent !). If the sensor appears to be attached, it could also be the optical sensor which is attached to the front cover just above the reverse switch - sometimes this gets full of fluff or I have seen a couple with manufacturing faults where the sensor flag gets caught in the optical sensor circuit board ... whatever the case, this is really a job for the service agent.
Good Luck
SOURCE: I keep getting "check and rethread the upper thread" error message
Hi....I also kept getting the check and rethread upper thread message, I\'d sew about 15 stitches and it\'d stop. Here\'s what I did. On the left of the machine, in the back there is a screw....loosen that screw, take cover off, then lift straigt up and out on the cover that has the 3 on it in your threading seqence. Next, I started inspecting and cleaning the thread route from top to bottom. Lo and behold....I get to the place where you come down the front of the machine and turn to go back up and I spot a little slit in the plastic piece so, when I was threading the machine I guess I was pulling it to far to the left causing it to wear a little slit in that piece....so, I finished cutting it off with a utility knife, used an emery board to smooth it down, put the covers back on and it works GREAT!!!! Who would\'ve ever that it\'d be so easy and save me a bunch of money!!! I sure hope this helps someone.
