Replace fuse 8 amp and Q406 part number RJK5020 both on the power supply board
Testimonial: "I am hoping this is the same solution for the TH-42PHD5 which is our model #. Will have my husband take a look at this answer. Fast Response!"
SOURCE: Black screen on tv
is probably the z or y board.. if u have sound the y is bad
and no sound the Z is bad
but is best to change both of then
SOURCE: Vizio GV47L screen went black and is now unresponsive
Change the main board if you have good picture and sound. If you don't have picture and sound, the inverter will also need to be change.
SOURCE: 32" flat screen that went black
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
SOURCE: tv screen went black and no sound
Look at the power supply first; look for burnt parts, bad capacitors, etc.
Please post back what you find. It sounds like at least you do have the 5V standby power supply working but the main supply is not getting the 'ON' command from the main board, or the power supply is gettin ght e 'ON' signal but failed to turn on.
SOURCE: Techwood HDMI 32'' TV - Went to black screen while watching
Am Martyn...ma Tv same model did the same thing this mornign while i played FIFA 2010 world cup on PS3 Fat...what could be the problem???
