I WANT TO PAIR MY HEADPHONES WITH MY COMPUTER. HOW DO I DO THAT?
First of all, does your computer have Bluetooth?
Many laptops do.
Most desktops especially older ones do not.
You can get a Bluetooth USB 'dongle' for $10 - $25 which should work to pair with any headphones. Pay attention to the version of Bluetooth supported, and whether your operating system is supported.
Heres an example https://www.startech.com/Networking-IO/Bluetooth-Telecom/USB-Bluetooth-4-Adapter-Class-2~USBBT2EDR4
SOURCE: Pairing bluetooth headphone and mp3 player
search for devices option and visibility!! plz rate this post
SOURCE: How do you pair your Insignia Headphones/ Headset
Go to Accessory Settings on your PS3.Then go to mange bluetooth devices and hit register new device. while doing this take your headset and put it in discovery mode. You do this by holding the power button and the it alternates between blue and red lights.It should work after that.
To test it go to audio device settings and see if it shows up.
SOURCE: pairing s9 headphones w/krzr
OK I managed to get my head set to work. Make sure the unit is charged, press and hold both the 'ON' button (on neck piece) and the "PLAY/PAUSE' button on the right earpiece. Keep holding then the LED should flash Blue three times THEN flash alternate RED and BLUE. You should then be able to Pair the Device. Good luck
SOURCE: Can't pair TDK BT-100 headphones to my Iphone
I managed to pair the device after plugging the bluetooth headset into the USB power slot. Then I press the main button for 5 secs until the red light started flashing very rapidly and I typed in 0000 and the headset paired off with my Iphone. Good luck
