Usually it means that the word is an adverb (modifier for verbs, adjectives or other adverbs). Adverbs are commonly made from adjectives. Note the adjective USUAL, by appending -LY to it we make it an adverb. The word LULLY is no adverb. It is the name of a French composer (XVII century) .
hello there
the fuel pump relay is number xvii 17in the Porsche technical manual in other way it is 3rd from right on the top row of you fuse box.
And fuse number 22 is also for fuel pump.
I hope this will help you?
The 7000i has 2 impression controls. on the R. side is a slide switch marked L, M, & H put it in the H position on the R. side of the print below the ribbon id a green lever pull it all the way to the front.
Konica lenses do not fit Minolta cameras. I think you messed something up.
Minolta MC and MD lenses worked on the older manual focus Minolta bodies. They will also work on the Phoenix and Seagull clones of the old Minolta bodies.
The Konica lens should only ever be mounted on a Konica camera.
Your 7000i is now a Minolta paperweight. You need to send your 7000i for repair or replace it.
You could also look on Ebay for another Maxxum body to use your lenses designed for the Minolta A mount. As a rule, camera lenses are not interchangeable. You can use any Maxxum lens on any Maxxum body as a rule, but Minolta changed their flash shoe after the original 7000 series. Flashes that work with your 7000i will work with any subsequent Maxxum.
Flash guns are not normally that easy to repair, and most of the guns for the Minolta 7000i are getting pretty old and parts are becoming scarce.
The first thing to check is that the batteries are good, make sure you are using rechargeable or some of the new high power AA batteries, cheap bulk buy batteries are no good for flashguns.
Second, make sure the battery contacts are nice and clean.
If you still have problems post again but with the model of the flashgun as well.
send it to a camera shop,the fungus may have spread to the flex circuit under the top cover. there are no new parts for this model so finding a camera repair shop to clean it may take a few tries.
get an estimate first.
