If you have 2 wires, one is the hot wire the other is the switch leg. No neutral. The neutral is most likely in the light outlet box. Need to run 14/3 from light outlet to switch box. Abandon existing wire. Connect black to hot wire at light outlet box, white to neutral at light outlet box, red to light fixture. Ground to ground and all exposed metal parts. At switch black to dark screw (feeds switch & receptical) white to receptical lite colored screw, red (switch leg) to switch. Bare ground to box (if metal ) and ground screw.
The RG-6900 Ryobi generator does not have (or need) a battery. It is a manual type with cord start. Voltages and specifications may differ slightly depending on which country the unit is intended for (110V vs 220V). The same applies to warranty and servicing agents.
Send your email address to eggie-at-scheffler-dot-co-dot-za and I will mail you the manual in pdf format (820kb). Substitute "at" and "dot" with the usual symbols to mail me.
i
just puechased a ryobi rg 6900 generator and it does not hahe a battery
or operators manual. I need to know how to operate it and what size
battery to buy
It's best to run all electronics through a UPS and surge protector. Small generators like the RG-950 are really for small power tools and lighting. The Ryobi RG-950 is only rated 650 watts which really means about 450 watts (70%) for continuous use. In general, a basic desktop or a laptop should be OK. A TV up to 25 inches and a 100w lamp, should be OK. If you try doing both at the same time, expect smoke followed by lights out. A UPS and Surge Protector are a must on small generators due to their poor voltage and frequency regulation. The UPS should be a good quality one that deals with Brownout, Overvoltage, and frequency deviation. ALWAYS USE A SURGE PROTECTOR!
