I have a compool 3400 system. The system has an error 4 code. I discovered that there is a red light fault on the air blower. I opened and connected the remote panel directly to the main panel board and the err code 4 was still present. So I put everything back to what it was and the system worked until the pump cut off and the again the error code 4 appeared on the remote panel along with the red fault light on the air blower. Any help appreciated!
Manual has troubleshooting and system options info
below. It has info of how to reset the control panel and power center..
May help
https://www.manualslib.com/manual/967826/Compool-Cp3400.html?page=41#manual
Another version of the manual below
http://www.poolinspections.com/manuals/controls/compool_cp3400.pdf
Only other think I can think of has any work been done or something go on which could have damaged the communication cable. May want to look at cable and end connections.
Testimonial: "Hi Kenneth, Thanks for the information. No repairs were done on the unit but the system suddenly went dead after a thunderstorm. I disconnected the communication cable between the power panel and the remote pane and tested communications between the two panels using he test communication cable. No change, the fault is still present on the air blower. Then put everything back with the original communication cable to the remote and reset the power panel and the remote panel. The system worked properly. When the timer cycle for the pool pump was complete and the pump shut off, the fault appeared again. Again reset the power and the remote panels. Still getting an error 4 and a fault on the air blower."
SOURCE: Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
SOURCE: Fault Code 37 Intuitive Washer -
you have a clogged diverter valve, its blue and looks like a Y, it will need to be replaced, if you want call 1-888-936-7872 they can order the part and walk you thru replacing it
SOURCE: Help with toyota corolla 2003 code P0420
CODE PO420 CATALTYLIC CONVERTER SYSTEM FAULT.ITS SAYING FAULTY CATALTYLIC CONVERTER.IF IT BEEN A WHILE IF YOUR CAR HAS A WHOLE LOT OF MILES ON IT.YOUR SPARK PLUG CHANGE IS DUE AT 120000 MILES. DUE A LITTLE TUNE UP CHANGE AIR FILTER AND FUEL FILTER.SEE IF YOU HAVE ANY ENGINE FAULTS BAD PLUGS DIRTY INJECTORS ANY THING UP SET FUEL SYSTEM CAUSE CAR TO RUN RICH.EXCESSIVE UNBURN FUEL WILL GATHER IN CATALYTIC CONVERTER CAUSE IT TO BURN OUT.SHORTING LIFE OF THE CATALYTIC CONVERTER.
SOURCE: Renault Clio Sport 182 Air Con and fan blower fault
I also have a 53 clio with climate control and the fan stopped working. After being quoted £104 by dealership I decided to have a go myself. Bonnet up, remove driverside scuttle cover. Unplug fan resistor 7701051272 (large plug with black wire to fan)remove securing screws and resistor. Dismantled casing and peeled away gel from soldered side of circuit board around mosfet transistor-desolder and remove. Mine was a N342AD 75344G but the nearest I could get was HUF75337P3 from Maplin £1.68. This was the wrong 'package size' but I managed.Close the clamp slightly (before)to hold transistor firmly and then insert transistor and solder. Reassemble. After I got an email from a scrappy QUOTING £20 if you don't fancy the messing about.
Ian
