Televison & Video Logo
Lorne Schuk Posted on Nov 01, 2019
I just bought a 65 inch RCA 4k tv, what would cause flickering or flashing over top of the picture?
Metal
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Sep 27, 2020
Metal
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
2071
Points
34
Does it happen on normal TV broadcast or just over HDMI?
I'd try another HDMI first, personally. Test all ports with a known good cable as a first test.
2 Related Answers
William
  • 188 Answers
  • Posted on Jul 20, 2009
SOURCE: FLICKERING PICTURE
Check power supply for the 24Volts connected to the backlight inverter ,bad caps could be the fault
Anonymous
  • 666 Answers
  • Posted on Mar 26, 2010
SOURCE: RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Samsung 65 Smart TV non 4k picture issue
The back light and the LCD need to be replaced for the TV.Also I would try unpluging the wires to the TV and see if the problem stops.
65 inch Bolva 4K Intelligent TV, with the image flickering and freezing after 2 minutes I turned it on. Could it be a default T-con board?
Sounds very like so. If you wish to get some details; check the site linked here. Pull up older posts.
https://elektrotricks.blogspot.com/
faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the brand name and model of your set, in its search bar at the right side column, and press enter.
Samsung curve 65 inch has no sound, has picture.. Using Bluetooth curved sound bar, no sound on tv speakers either
Hi!
Check your power amp circuit. Or, check if it is feed by the power supply circuit. Good luck,
Serge.
Rca 42in full hd lcd picture flickers
If the picture on your TV flickers, there may be a simple fix. Here are some possible answers and suggested solutions:
1. Your set-top box may need a simple reboot. Unplug the power connection to the set-top box for about 30 seconds. Reconnect the power and turn the set-top box back on.
2. Check all of your cables for a loose connection by tightening each one with your fingers.Flickers can sometimes be caused by bends in rigid cables, too.
3. If your picture flickers to a black or blue screen, you could have a bad set-top box. Contact your cable or satellite service provider about installing a new one.
4. If you still have audio, the flickering could also mean that you have a failing backlight.
For additional troubleshooting information, check out the chart at TV flickering for more solutions. I hope this helps!
2answers
2answers
RCA TV flickering problem
Your tv has a video problem, leak capacitor in video section, near in flyback need to replace it.
Negative picture,lamp indicator flahing 3 minutes after turning tv off
I changed my lamp in the 65dr650 but the picture still looks like a black and white tv and flickers
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
