SOURCE: bell express vu remote codes for soyo tv
1 - Hold the clear tv buttom until all 4 light flash red
2- Press the red tv buttom
3- Press the amount of time needed on the up cursor ( around select buttom) until your tv shut down
4-When the tv goes off press the search buttom ( at the end on the right side )
5-Press record
Then u can use the red tv buttom to control ur tv and u can control the volume on satelitte mode without going back to tv mode , if u press too much time while searching the code and the tv wont light back , do the same thing but instead pressing the up cursor press the down one to go back on the code it will be faster .
SOURCE: need tv codes
codes are:
0906, 0702, 0203, 0306, 0208, 0911, 0842, 0942, 0504
one of these should work
SOURCE: I need codes to program direct tv remote (20.0IR EchoStar 158926)
Press 'Menu'
Scroll to 'Customer support' and Press Select
When the application loads you'll see the codes menu.
