Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw Logo
Posted on Sep 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2.3 ci chainsaw 16in. sparkplug size and number
  • Anonymous May 11, 2010
    We need the make, model, and serial numbers from the manufacturer?s tag to help you further. We also need to know if it is European.
Anonymous
Level 3:
President:
  • Master 2,220 Answers
  • Posted on Sep 18, 2009
Anonymous
Master
Level 3:
President:
Answers
2220
Questions
Helped
1384418
Points
7625
Take it with you to your local chainsaw seller or auto store. Don't drop it. HTH
Lou
Anonymous
Level 2:
Sergeant:
  • Expert 384 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
384
Questions
0
Helped
222318
Points
916
Take the Plug out of the saw and read the part number.
I need the bolt that holds chain brake handle on at bottom.
Try IS Engineers - you can find them on google. They are very helpful and will, if essential, send a parts diagram with part numbers so you can choose the part you need then order it online.
1996 jeep Cherokee has a high idle problem
You have asked a vehicle based question in a Chainsaw category. Please try again.
Repair manual for craftsman 32cc 16in chainsaw
go to www.managemylife.com enter your model number in the search bar under the manual tab. your model number will be a 9 digit number on the id plate, it will start out with either 917 or 247.
Wont start replaced sparkplug and does turn
Just chenk that it is mechanically sound, remove the muffler and check the condition of the piston skirt through the open exhaust port, any signs of scuffing and it will need to come apart to assess the damage.
We have a model 137 chain saw. I need to know what size file to sharpen the chain and the correct angles for this model.
all saw blades are sharpened to the same angle. 37° the file size you are going ot want is 1/4-3/16in.
2helpful
Echo chainsaw 16in. model 280 E(P) or 290 EVL(P) \r\nLooking for the correct oil and gas mixture ?
The mixture for most echo products is 50:1 ratio. You can use the Stihl fuel mix in this unit .. The Stihl fuel mix is also a 50:1 ratio.
Mar 29, 2011 • Echo Garden
Engine misfiring.
most all v8's have the same firing order which is 1,8,4,3,6,5,7,2. sparkplug gap seems fine. with the engine off, bend the sparkplug wires between your fingers, if small cracks appear then replace them. number one sparkplug is located at the front driver side of the engine, front to back on this side are cylinders 2,4,6, and 8 respectively. turn the engine to the compression stroke on number one, pull the cap, the rotor points where number one will be.
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
