HP LaserJet 2820 Printer Logo
Posted on Sep 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP Laserjet 2820
When I print my yellow cartridge is printing yellow lines all over the page. Almost solid yellow all over, still has other colors, just underneath the yellow.
NANDAKISHORE
Level 2:
  • Expert 304 Answers
  • Posted on Sep 18, 2009
NANDAKISHORE
Expert
Level 2:
Answers
304
Questions
11
Helped
107048
Points
887
Replace Yellow Cartridge or its Drum.
I installed an original Q3971A toner into the HP 2840 laser printer, However there is still a notice to install cyan catridge. Can you help please
PDF]HP Color LaserJet 2840 and 2820 All-in-One for small and ...
h10010.www1.hp.com/wwpc/.../clj2820_clj2840_bro.p...
Hewlett?PackardColour laser printing. HP Color LaserJet ... •Convert hardcopy documents into digital format for easy ... Color LaserJet 2820 All-in-One gives you high quality, ... Oth ring. Why HP. Save time. Printing a file. Printing a paper fax. Receiving a .... Install, configure and manage multiple networked ... Replace toner cartridges easily.
HP Environment: Product Safety Information - LaserJet ...
1helpful
Laserjet hp ce3525dn has a yellow background and yelow layer over my color printing
1. Scroll to and touch Administration.
2. Scroll to and touch Troubleshooting.
3. Touch PQ Troubleshooting.
4. Touch Print.
Chk PQ test pages, if yellow color arrests entire page?.. Two reasons
1. Yellow cartridge.. ( swap with another one & chk )
2. Chk yellow cartridge contacts, clean them with isopropyl alcohol.
Chk base contacts, broken?, dis placed?, not contacting?..etc ...Remove & refix DC controller board...
The logo in my print job is color Green but its coming out in color blue. what is the problem
Check the yellow toner cartridge, printing a configuration page.
Configuration page
The Configuration page lists the current settings and properties of the printer. You can print a
Configuration page from the printer or HP Toolbox. To print the Configuration page from the printer,
complete the following steps.
1 Press the (LEFT ARROW) or the (RIGHT ARROW) buttons to select the Reports menu.
2 Press the button (SELECT).
3 Press the (LEFT ARROW) or the (RIGHT ARROW) buttons to select Config report.
4 Press the button (SELECT) to print the Configuration page.
Yellow print OK?
No? try print with another yellow toner cartridge (Q6002A).
2answers
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
2answers
My boss want to replace the black ink cartridge for one that prints color. Can this be done with the HP 12-a cartridges? HP Laser jet 1022
Unfortunately laser printers don't work this way. The laserjet 1022 was designed for black and white prints only. In order to do color printing with a laser printer you will need to purchase one that is designed to print in color. The laser printers work a bit differently than the inkjets - the laser printers have 4 toner cartridges, one each for Cyan, Magenta, Yellow, and Black, that work together to print a full color page. With the old inkjets you could just replace a black cartridge with a color one.
So, short answer: Sorry but no you can't make a laserjet 1022 print in color. :)
I would recommend looking at an entry level color laser printer from hp, such as the CP2025 (http://h10010.www1.hp.com/wwpc/us/en/sm/WF25a/18972-18972-3328060-15077-236268-3673580.html) if you are looking into purchasing a color laserjet.
Hope this helps
Please rate this post, thanks!
Hp color laserjet 2840 - prints one page in color, next in black & white. Yellow ink cartridge light blinking. Says "replace supply, using black only". Yellow wasn't showing as low previously.
Follow each of these steps until the problem is resolved:
Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
Remove and then reinsert the print cartridge(s) into the printer.
Print the document.
If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
Try printing again. If the problem continues, replace the print cartridges.
http://www.fixya.com/support/t5717191-hp_deskjet_6540_printer_yellow_light
2answers
HP LaserJet 1500... prints color yellow ONLY
It's possible that the toner in the cartridge is not evenly distributed. You can redistribute toner if you gently shake the cartridge from side to side, then reinstall it to see if this affects performance. Please also see this article.
You might wish to use the guided troubleshooting option available from HP support here. Or have a look at the troubleshooting section in the user manual here. Then clean the engine & calibrate the printer, as described pg. 88.
If that's no help, please see this forum post and the linked attachments within.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
C88 / T060 cartridge refilling problem
sounds lke your yellow nozzle not working properly...had same issue on lexmark printer, ended up geting this epson...learnt from my mistakes...perhaps it ran dry? or you left the yellow cartridge out longer than the rest....only you might know what happened
1helpful
Color cartridge not being reconized
I recently spent six hours troubleshooting the exact same problem (swapping all kinds of parts and motors) except with mine only the yellow would print and one time the print came out correctly. If you know how to take the machine apart, this has to do with the carousel drive motor positioning solenoid. The solenoid has a pad that is a silencer for the solenoid are the starts to deteriorate and "sticks". You could fix this (with electrical tape over the pad) or replace the solenoid. Either way, you need to get to the part.
k24674
Grand Canyon Tech
Grand Canyon Tech
