SOURCE: won't receive faxes
Make sure the receive faxes button is set properly. If it is not set to fax only, you will need to manually receive faxes, the machine will not auto answer.
SOURCE: Fax not sending or receiving
hear fax can send but fax is recevieing so what is the solution
SOURCE: Fax tones heard during tel conversatio
Kindly check your incomming line connected in Line In port of machine . And change your receive mode as TEL/FAX .
Again the same will happen the probelm related to its Line Interface Unit. Change it and check, your problem must be solve.
SOURCE: The fax no longer transmits. It finds the dial
If there is a poor line or connection, reducing the transmission start speed may correct the error.
Reduce the transmission start speed. Refer to "TX start speed" in "Device Settings" of the User's Guide on-screen manual.
