SOURCE: can't get Blueray player to release DVD
You may now have corrupted firmware. did the dvd contain the firmware update?
Are you sure there wasn't already a cd in the tray? (Ie two cd's are now inside?
The easiest way to remove the cd if turning off fails is to remove the screws around the casing. Lift off the lid and the cd should come out easily, however if the update was corrupt or the wrong firmware you may now have a dead player.
Try removing the Cd as described first with the power off and plug removed.
Then see if the unit powers up and the drawer opens.
If so you may be able to revert it to its original firmware from the vendors site.
Regards
Marc
SOURCE: When tv is wired to
Hi.
When you say disk will not play I assume the BRD player does not start playing.
If the Blue ray unit does not start at all and stays in stand by , then the HDMI cable you are using to connect to TV, or HDMI port on TV may be defective.
Try replacing cable and swapping HDMI ports.
SOURCE: Magnavox NB500MG9 BluRay Player
A Blu-ray player can play DVD or CD and still not play Blu-ray. It may play Blu-ray but not CD or DVD, or burned discs. This is all caused by the 'optical' a part that reads the disc in the machine. Your player will need service as a Blu-ray optic cannot just be 'dropped' into a player.
Testimonial: "good answer I upd soft,cleaning the lens izopropil but I can not read only regular dvd the service guy was asking for the same price like the new one"
Its brand new
