Voir d'abord ces aides, probablement un bruit normal.
https://www.lg.com/us/support/help-library/refrigerator-noises-CT00023125-20150292153479
SOURCE: Refrigerator Compartment Fan
Sounds like they ran it in with your themostate and it is not working.. i would try replaceing themostate
SOURCE: LG refrigerator NOISE
I have the sam eproblem...another site I went to said it is ice build up on the fan. Unplug the frig for an hour (don't open the doors or everything will spoil) and then plug in...it may defrost a bit and allow the fan to turn freely.
SOURCE: Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
SOURCE: Our 3 yr old LG Model LFC25760SW French door
Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing
it out with hot water and clorox may help.
Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the
lower back of the freezer.
SOURCE: my LG refrigerator model #
my refrigerator before making a loud noise when we open the door. i called mr.apliance he replace the evaporator fan.......
