Turn off fixed tv speakers hook up sound bar with Digital Optical and then program remote. You have to use you vizio remote and your TV or cable remote also for this step.The steps are in your vizio book.You have to go to menu on the vizio remote press the learn volume down press play and press your TV or cable remote down at the same time as learning and then do the same for volume up and mute.
1. Plug in the power cord.
2. Plug in the optical cable from your TV to your sound bar.
3. Turn on your TV.
4. Turn on your Soundbar.
5. Check the audio on your soundbar and make sure it's set to the right input.
Guide attached:
SOURCE: CANT GET SOUND FROM SOUND
I had a similar problem. I tried all the TV settings, but still it would not work. I plugged the sound bar directly into the cable box (AT
SOURCE: I HAVE A VIZIO SOUND
Hello, Daniel Busa with Dish Network's customer service try these steps if the remote will program this will do it
SOURCE: I Have a 5.3 IR
lojr, (VCR button instead of TV button)
We have code to use with amplifiers, TVs, VCRs, and DVD players. I do not have a code that will work on this sound bar. What is the code you are trying to use? Did Vizio supply a code with your sound bar. They do have codes to use for their TVs to program DISH remotes. Please let me know if you have a code or you can contact Vizio to see if they have a code available.
I have provided the Power Scan instructions on programming the remote to a sound bar. Use the VCR button to attempt to program the sound bar.
If you have further questions, please post it here.
Ray Calo
DISH Network - Executive Offices
Power Scan Instructions Power Scan Instructions
1. While at the sound bar location, point the remote
at the sound bar. Press and hold the VCR MODE button on the remote until all four MODE
buttons at the top of the remote light up.
2. Press the RECEIVER POWER button on the remote.
3. Press the UP ARROW on
the remote, about one press every two seconds. Stop as soon as the sound bar turns
off. This process may take several minutes.
4. Press POUND (#) on the remote. The VCR MODE button will
flash three times.
5. Press VCR MODE button, then red TV button on the remote to turn on the sound bar. Press
VOLUME on the remote to confirm the remote controls the sound bar. If this does not
work, return to Step 1.
Remember to press the SAT MODE button to return to the Satellite mode to change channels.
SOURCE: cannot hook up vizio VSB200
I have questions about sound bars myself so just today I call LG about My 42LD450. The first thing the agent said was to not get the Vizio, he said that the 42 just will not work with the Vizio.....just a lil tidbit of info ......
SOURCE: Why is my Vizio VSB200 sound bar not having
my soundbar vsb200 no sound at all what im i doing wrong
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Vizio-VSB200-Speakers-manual/id/23494ag923/t/2/
The manual shows connections to just about anything.
Not knowing anything about YOUR receiver, you MIGHT be able to draw digital audio out somewhere. Analog audio would be available at any Tape Output. Your receiver
