SOURCE: Smoke alarm keeps bleeping
Here are the steps:
Was this always like this? If not, change the batteries, clean it up. Consult the local fire dept. The help for free.
If that does not work, you will need to get it serviced/repaired.
Cheers
TeaCii
If you own website, add
live support almost free
Real
security guard to watch your cctv for $1/day
SOURCE: how to stop dicon smoke alarm beeping
All smoke alarms beep if the battery is too low. Getting a used battery isn't good enough for smoke alarms. Even getting a new battery from a dollar store (a cheap no name brand import store) will not do... it has to be the newest and it has to be alkaline. once you put it in... press the button for 10 seconds... first you will hear it's own alarm then you will hear the others attached to it in the whole system chime in (if you have that type) the alarm will now sit quietly.
SOURCE: how can I change battery of smoke alarm model 1275?
If this is a Kidde 1275CA alarm, then grip the outside and turn it to release from mounting bracket, then on the underside is the battery housing to be slid off to replace!
