Washing Machines Logo
R
Robert Heigold Posted on Oct 23, 2019
Exact outside width of LG 43UM7300 43-in.to ensure that it will fit in my cabinet.
debidick
Level 1:
New Friend:
  • Contributor 37 Answers
  • Posted on Oct 26, 2019
debidick
Contributor
Level 1:
New Friend:
Answers
37
Questions
0
Helped
27819
Points
87
These any good ? Direct from the LG site:
TV Dimensions with Stand (WxHxD)38.3" x 24.8" x 8.5"and TV Dimensions without Stand (WxHxD) 38.3" x 22.5" x 3.3"
Good luck.
I have a Singer model 4530. Can this go into a sewing machine cabinet?
Yes, the Singer 4530 should be able to fit into most standard-sized sewing machine cabinets. Make sure to measure the size of your cabinet to ensure the Singer machine and all its accessories will fit inside.
What are the dimensions for an old Tappan Double Wall Oven Model Number 11-2969-10-01?
Nothing exists online for that. You remove it from the cabinet and measure the gap width and height. Then put the rule in to the back and measure to the edge lip. Take 6" off that measurement for an air gap.
https://www.google.com/search?q=Tappan+Double+Wall+Oven+11-2969-10-01+dimensions
How do u fit door seal on a zanussi fjdr 1666w
Removal of the Seal.
Remove plastic clamp holding seal to cabinet and peel off the cabinet. Push downwards on the seal close to the tub and the seal will come off - its just held by a spring around the outside.
To fit the new Seal.
Lubricate the slot which fits over the tub with washing-up fluid.
Starting at the top, press the seal, so the flange of the tub enters the slot on the seal.
Work your way round the using thumbs to force the slot on the tub flange.
When the slot is on the flange all way round, fit the spring which holds it on.
The spring goes into a slot on the outside of the seal.
This is difficult, you may need another pair of hands.
Fit the outside of the seal to the cabinet and fit the plastic clamping ring.
Test for leaks.
Use Rinse to test for leaks, since the water level is higher.
How much breathing space does a refrigerator need NONE, 1/2 inch or 1 inch above the top of the cabinet for air circulation. Sears has told me all 3. WHICH IS CORRECT?
For airflow it would be the back that needs clearance of a couple inches. Top of unit shouldn't matter. Inside the fridge itself if you plan on packing it as full as possible except for the amount space needed to allow airflow,. I would just atleast leave 1 inch on every side. But outside of fridge just leave clearance in back and front. Google manual and it will tell you
1helpful
2answers
I need to know the internal measurements of the kitchen cabinet that would fit this oven
If you need specification for some oven, doo a Google search for ti. might use terms
SPECIFICATIONS, MAKE, MODEL OF OVEN
or look for user's manual
MANUAL, MAKE and MODEL of oven
According to specified measures you can look for a cabinet for the oven.
Now, apart of measurments, it's not a good idea to keep an oven in a kitchen cabinet.
Light blinks off and on when door is open
If you mean that the freezer cabinet light flashes check the lamp fitting and ensure the bulb is fully tightened, they have a habit of becoming loose with the expansion and contraction of the fitting/bulb as the freezer compartment cools with the door shut and the bulb warms when the door is open.
Exact Outside Width Of The Ge Jx2127sh Microwave Trim Kit. Does anyone know the exact total width of the GE JX2127SH Trim Kit? None of the GE sites list the outside width.  Extrapolating from the cutout...
I would go with it. The 1/8" on each side you are worried about can probably be trimmed if need be. The manufacturer is usually very precise on an measurements they publish.
Dave
1helpful
What are the exact cabinet dimensions of a Roper dishwasher, model #RUD3000? Thank you!
The manufacturer specified cabinet dimensions for this model are:
Total width: 23 7/8" / 606mm
Total height: 33 7/8" / 860mm
Total depth (front to back): 24" / 610mm
If you need any further specifications for this model, please reply within this solution.
Regards,
BElectric
6helpful
Specific dimensions of a side by side model 532
FINISHED ROUGH OPENING DIMENSIONS: WIDTH = 47 1/2" HEIGHT = 83 3/4"
DIMENSION OF 532: H=84" W=48" D=24" MINIMUM HEIGHT=82 7/8" DOOR SWING=29 1/4"
2helpful
Wall Oven does not fit flush into built in cabinet
I HAVE SEEN SOME CABINET MAKERS BUILD A TRIM PIECE THAT GOES ALL THE WAY AROUND THE EXISTING HOLE THAT HAS AN OUTSIDE DIMENSION LARGER THAN THE CABINET HOLE AND AN INSIDE DIMENSION TO FIT THE REQUIREMENTS OF THE OVEN. IT ATTACHES TO THE FACE OF THE CABINET AND STAINED TO MATCH THE CABINET FINISH.
Apr 10, 2008 • Ovens
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
