Question about Archos 504 500870 Digital Media Player
Starts but won't stay on, spontaneous start/stop cycles,FAT error
Starts spontaneously on its own and sometimes when I actually push the button, but won't stay on long enough for me to use the menu. Got a FAT error message once, but mostly it just turns on with the opening ARCHOS page and then turns off (with a little 'dink' noise) before it gets to the menu. If it does get to the menu, it turns off before I can choose anything. Often says it's suspending before it goes off completely.... but sometimes will cycle through the opening page and turning off several times on its own, especially when I move the tablet around a bit.
I only started using this tablet, probably got about 4 hours use from it before it started acting up enough that it's been pretty much useless ever since.
Saniflo compact part flushes when being used
Of course you should , the MAKER should make it right
May 22, 2017 | Home
Pump starts spontaneously without pushing the switch button
This sounds as if a relay has gone out on the circuit board. There really could be no other reason for the pump to come on without pushing the button.
You will need the model number of the control box so you can find a replacement.
Rod
US Parts Center
Jan 18, 2013 | Maax Home
My Dell Inspiron 1525 with Vista shutdown spontaneously
I think you may have a virus? I recommend that you do a System Restore to the time, you say about a month ago? anyway, restore it to that time & hopefully the problems will be gone.
Feb 06, 2010 | Microsoft Windows Vista Home Basic Edition...
My Dell Inspiron 1525 Shutdown Spontaneously
Generally with laps the reason for a spontaneous shutdown is power. Either your battery is low or the transformer for power is going bad or is bad. There is information under the control panel, then power options which show the power settings and a meter to check the amount of power left and what is being used for power. Check those two items and you may fine your problem. Also make sure the battery is properly inserted into the slot, if it is loose a bit of movement may trigger the shutdown.
If either of these work please leave feedback.
Feb 06, 2010 | Dell Computers & Internet
Fisher paykel dishwasher dd601I runs complete normal cycle and finishes normally. 2-3 sec. after completion the washer motor srarts to run and the f1 fault (flood sw. activated) is dislayed. When the power...
Hi
F1 code indicates an overfill condition which may cause when dishwasher can’t pump out dirty water due to a plugged drain hose.
open dishwasher fully ,dry up as much water as possible then put a hair dryer on hot and direct into the back of the cabinet you will see a grey plastic cover on the bottom floor this is the sensor run on full for about 5 - 10 minutes making sure the heat go into that area. Also don’t overheat your hair dryer, when finished close the dishwasher shut and start your normal cycle.
Thanks for contacting fixya.com
Jan 20, 2010 | Dishwashers
Sudio 17 spontaneously shuts off
Troubleshooting With PSA Diagnostics on a Laptop Computer
STEP: Run the Preboot System Assessment (PSA)
Additional Information
  1. Ensure that the computer is powered off.
  2. Press and hold <Fn> and press the power button to power the computer on.
  3. Release both buttons. The PSA diagnostics sequence begins.
  4. Make note of any PSA beep codes or PSA error codes
  5. check PSA error code on support.dell.com
Dec 09, 2009 | Dell Studio 17 Notebook
Audi A8 onstar spontaneously activates
if there is nothing pushing the button, it will be a fault in your Onstar button. It could have possibly had soda spilled on it, not saying it did, but that would definately do it in
Jul 25, 2009 | 2001 Audi A4
Dishlex dx302 keeps beeping after every 2-5mins of operating..i hold down the start button for a few seconds then push the programme button and it starts operating again for only a few minutes
I had this problem, also. I just persisted with it for a week (re-initiating the start) & eventually it came good. Was very frustrating for a while. Your post was over two months ago; did it spontaneously resolve for you?
Chris
Jun 27, 2009 | Electrolux Dishwashers
Horn spontaneously go off and will not stop unless the fuse out
the horn switch is part of the sterering wheel assembly.
it needs yto be changed
Apr 10, 2009 | 2004 Jeep Grand Cherokee
Archos 504 500870 Digital Media Player Logo
73 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
 Mike M
Mike M
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
