My mobile does not read memory card
when i open memory card it shows
MSDC read sector error
MY MEMORY CARD PROBLEM ..1 DIVICE LOADE 2 SECTOR NOT OPEN MEMORY CARD
Remove the memory card and get it read in the card reader in the pc and if works backup the data and if not try formating it through
my computer>right click card icon and format it --if it works you can start using and if there a problem re format it through mobile
Format the memory card
MSDC read sector error generally occurs due to memory card corruption issues. To get rid of this, you must format the card and then use an updated backup to perform digital image recovery from mobile's memory card.
Remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation.
If the card does not read in any PC then it has damaged sectors and might need to be replaced.
