Saws Logo
M
Miguel Abreu Posted on Oct 22, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where to get blade guard for master craft 055-6745-2
barn2897
Level 2:
Habit-Forming:
New Friend:
  • Expert 153 Answers
  • Posted on Nov 28, 2019
barn2897
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
153
Questions
0
Helped
67387
Points
428
Hi Miguel-
I found this link.
https://www.canadiantire.ca/content/dam/canadian-tire/manuals/0556745_EN.pdf
If you need replacement parts contact "canadiantire" at 1-800-689-9928 for help.
Hope this helps.
2 Related Answers
Anonymous
  • Posted on Nov 12, 2007
SOURCE: andis masters are chewing my guards
Stop using speedo guards and get yourself an oster 76 and all the blades.
Kevin Prendergast
  • 371 Answers
  • Posted on May 07, 2015
SOURCE: Hiw to replace blade on master craft 140 cc lawnmower
Bolt on the bottom. Watch out for LEFT HAND THREADS!
Have a master craft band saw model v1332 cant seam to find blade size can you tell me what the size is
If your bandsaw doesn't feature in any of the catalogues of the major blade suppliers it is probably an unusual size and unless available from the original manufacturer or importer you will probably need to have blades made to order or buy a length of blade and using a blade repair kit, produce your own.
A great many blade suppliers will produce a custom blade, either from supplied dimensions or from a supplied pattern.
Jun 18, 2019 • Blade Saws
How to remove splash guard from base
Good evening
it is difficult to take the bottom things from each other. The blenders I know are screwed to each other,
all the best
kolbrun
Why is my blade hitting the blade guard
Hard to say without seeing it but....wrong sized blade, bent blade, clamp missing or installed wrong, bent guard, or bent blade shaft. I'd look in that order. Hope that helps.
1helpful
2answers
Blade guard for power craft compound mitre saw WK 1200
Lows, Home Deport, Ace Hardware, Tractor Supply, Target, Wal-Mart. Kmart, about any major store. Harbor Fright. Etc.......
Jun 23, 2013 • Saws
Can't find my owners manual. How do I change the blade. Bolt hits on a guard that covers the arbor. On a DW713 combination saw.
Removing the Blade
1. Unplug the saw.
2. Raise the arm to the upper position and raise the lower guard as far as possible.
3. Loosen, but do not remove guard bracket screw until the bracket can be raised far
enough to access the blade screw. Lower guard will remain raised due to the position
of the guard bracket screw.
4. Depress the spindle lock button (Fig. 3) while carefully rotating the saw blade by hand
until the lock engages
5. Keeping the button depressed, use the other hand and
the wrench provided to loosen the blade screw. (Turn
clockwise, left-hand threads.)
6. Remove the blade screw, outer blade clamp, and
blade. The inner blade clamp may be left on the
spindle.
Installing a Blade
1. Unplug the saw.
2. With the arm raised, the lower guard held open and the
guard bracket, place the blade on the spindle against
the inner blade clamp with the teeth at the bottom of
the blade pointing toward the back of the saw.
3. Assemble the outer blade clamp onto the spindle.
4. Install the blade screw and, engaging the spindle lock,
tighten the screw firmly with wrench provided. (Turn
counterclockwise, left-hand threads.)
5. Return the guard bracket to its original position and
firmly tighten the guard bracket screw to hold bracket
in place.
WARNING:
• The guard bracket must be returned
to its original position and the
screw tightened before activating
the saw.
• Failure to do so may allow the guard
to contact the spinning saw blade
resulting in damage to the saw and
severe personal injury
you can download a manual at: http://www.dewalt.com/tools/machinery-miter-saws-dw713.aspx
Jul 20, 2010 • Garden
2helpful
Circular saw blade rubs on the guard
remove the blade and check for the inner flange that should be behind blade. also there might be a ring underneath the inndr flange. or check to make sure the flange is installed correctly.
Apr 05, 2010 • Ryobi Saws
2helpful
2answers
Change blade
OK first raise the cutting head. Loosen the screw that holds the guard in place and move out of the way. Find the spindle lock on the right hand side of the gearcase and turn blade by hand (UNPLUG SAW FIRST) until it locks. With the wrench supplied with saw put it on the blade bolt and turn it clockwise to loosen, it has left hand threads, remove outer flange and blade. Let me know it you need any more help
3helpful
4answers
Andis masters are chewing my guards
Top Blade Saws Experts
Paul Carew
Are you a Blade Saw Expert? Answer questions, earn points and help others
