SOURCE: my ac circuit breaker keep tripping
If your outside condenser has a locked rotor or short circuit, than the unit WILL trip the breaker - as it should. On the other hand if a breaker is tripped a few times it will have less of a capacity that the rating, (this is designed in it). You will need to determine if the unit is locked (and broken) or the breaker has become too sensitive.
SOURCE: Pond pump trips circuit breaker
The circuit breaker trips because there is an electrical short in the pump itself or in the wire feeding the pump. A cause of this could be a bare wire, or a crack in a wire. Remove the pump and put it in a five gallon pail of water and test it. If it still trips the breaker you will know the problem is in the pump or the cord to the pump.
SOURCE: two 15 amp arc fault breakers installed on two
It's possible that the first breaker that you said does not trip - it could be that breaker is failing to trip on a bad circuit. That is, it could be you have a bad circuit but that first breaker is not detecting it and pretends everything is OK. If your new breaker trips on the first breaker's circuit, the curcuit it probably bad and the breaker in not working properly. The most common problem for failed circuits is a stray ground wire in a box somewhere in the curcuit resting against a hot or neutral wire. You'll have to take apart every connection on that curcuit to find it. Not fun.
SOURCE: breaker relay tripping out
If the unloading valve trips , which i think is the safety valve that tells me the compressor is pumping up past its maximum allowed pressure. that black switch should be the overload switch. check the amps of the wires going to the motor while its running and then look at the name plate of the motor to see the maximum amount of amps that the motor is allowed to draw.
SOURCE: copy of the NordicTrack C2100 owners manual.
You can get the manual here on link below.
http://www.iconservice.com/cgi-bin/ncommerce3/ExecMacro/nordictrack/manuals.d2w/report?man=NORDICTRACK&name=c2100&lan=&x=52&y=11
