Good luck finding the wiring diagrams for those factory u free. I am on here to give my technical expertise though and not do peoples extensive Google searching work for them.
https://www.clublexus.com/forums/is-f-2008-2014/892831-electrical-wiring-diagram.html
The information you are looking for is copyrighted therefore you are probably going to have to pay to get it. See the link. It is possible to find free copies of there stuff floating around out there but most of it is bogus sites. If you do a ridiculously extensive search I was able to find factory service manuals for my cars.
SOURCE: Cannot find wiring harness
HEY THERE. I'M HAVING A SIMILIAR PROBLEM. I CAN'T GET A REMOTE. THE NUMBER FOR THE MANUFACTURER IS
(323)-588-2999. I HOPE YOU HAVE BETTER LUCK THAN I DID.
ALLEN
SOURCE: car radio harness colour code
work it out with a meter ,,,,find perm 12v feed neg and pos ---yes could be any coloured wire depending on car maker,after finding perm 12v feed for memory look for pos from ign switch,now speaker wires are easy as both will be same colour for a speaker but one will have a band through it if not sure or colour blind like yours truelly then use pos and neg on speaker wire till you hear a thump from speaker then you know you have the right wires and location of speaker ,,ie.. front left back right ect ....Now you are a fully experianced radio fitter ??
SOURCE: Need a Nak CD-45Z wiring harness, or diagram
Rob, I had the exact same problem, I kept searching on line and came upon Alex in Australia, he deals in Nakamichi products, and has the part (plug/wiring harness). He charges $55 for the part and $30 for express shipping.
Here's his email:
[email protected]
I have also found a site with the Manual: http://www.nakremotes.com/default.htm
Click on "Model List" and look for your model, in the manual there's the wire color code for the pinout. I also have the pinout by wire color, no room to include, will send in another response.
TOP
[ 1 2 3 4 5 6 7 ] Looking @ pins in socket
[ 8 9 10 11 12 13 14 ] Naka CD45-Z deck
Note: The above diagram is done from the perspective of looking directly on to the connector pins. If you are having trouble figuring out which way is which, just use the ground wire, which is always black, as a reference for making sure you are doing the pins correctly.
SOURCE: Installing an aftermarket head unit into a 1994 Ford Bronco
are you using and after market harness to go from your bronco to the harness to the new radio. if so make sure all the colors are matched up (e.i. purple to purple, purple/black to purple/black). did the speakers work before the aftermarket unit. Also check the wiring at the oem speakers
SOURCE: I am replacinng the factory
the orange wire in the #8 cavity is your key on power wire, so yes you need it the yellow wire in the #1 cavity is the 12 volt alwise wire so you need it as well the orange wire in the #10 cavity is the right rear speaker wire + you also need it hear is the wire list.
wire #1. yellow 12 power with key on
wire #2. gray interior lights
wire #3. green right rear speaker -
wire #4. red right front speaker +
wire #5 black left front speaker -
wire #6 brown left rear speaker -
wire #7 gray power antenna
wire #8 orange 12 volt power hot all times
wire #9 pink interior lights
wire #10 orange right front speaker +
wire#11 blue right front speaker + ( door )
wire #12 empty
wire #13 empty
wire #14 yellow left front speaker + (door)
wire #15 white left rear speaker +
wire #16 black/orange ground
