Question about NAD Audio Players & Recorders
My NAD T755 can't change listening mode to surround sound.
    Top Expert:
  • NAD Master
  • 10,535 Answers
5 Suggested Answers
6ya staff
SOURCE:
ABRsvcs
  • 4234 Answers
SOURCE: I have an av316 NAD,
Having the speaker wires hooked up backwords will not cause protect mode. If the wires were crossed (in other words shorted), that would. Disconnect all speaker wires, if the unit is still in protect mode, than the output transistors are probably shorted and the unit will again require service. Upon return from service, I would turn on the unit without speakers to insure that the unit at least works that far. Also, if you have an ohmmeter, measure across the speaker terminals. You should read either 3 or 6 ohms. If you read 0, the problem is a shorted speaker that then shorted the amp.
Keep us posted.
Dan
Posted on Jan 21, 2009
Anonymous
SOURCE: NAD 775 will not play surround sound from XBOX
try to calibrate the speakers from audessy rom menu,i did it and it lokes like it just needed to register all the channels,hope it helps.
Posted on Mar 09, 2009
ryancsmith
Ryan Smith
  • 62 Answers
SOURCE: no sound in listening modes except pure audio
Check the input mode on the reciever so that they are set for dual, rather than just digital or analog. It might be set for analog and your using a digital optical in cable. Also make sure DTS mode is turned off, unless your watching a DVD that is dts enabled.
Posted on Aug 06, 2009
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: NAD T-763 receiver. cannot get
Have you looked at the manual? There is no internal source that would produce 7.1 audio other than the test tones. Attach a multichannel source according to ITS manual.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/NAD-T763-Receivers-manual/id/8043bh646/t/2/
Posted on Apr 20, 2011
Hi guys. Having a problem with my NAD T163 Surround Sound Decoder. Popping in front left and right speakers when changing audio selection. Works well other than that. Please give me some suggestions w
Could be DC voltage on the speaker output line, but this will generally keep your receiver audio output turned off completely. Could be a bad muting transistor or microprocessor IC(computer within your NAD). If you are interested in having your NAD repaired, please visit my website at audioserviceclinic.com.You may contact me there. Thank you..
Jan 01, 2014 | Sony TA-E9000ES Amplifier
NAD 7140 input selector does not work
The selector chip is not working, either there is no B+ to the ic or the chip has malfunctioned or one of the surrounding components dead, for this type of problem a schematic will be needed to track the problem. try www.nad.com contact customer support and the technical department for additional help.
Jun 15, 2012 | NAD Audio Players & Recorders
NAD T-763 receiver. cannot get surround sound. all speakers work. should the 7.1 and or surround be connected to the receiver and what else. stereo works fine....two front speakers, in stereo mode. ...
Apr 19, 2011 | NAD T763 Receiver
VIZIO VHT510. soundbar and subwoofer work. No sound from satellite speakers
Do you have them connected to the sub? Those satellite speakers pick up the fainter sounds and work best in movies with 5.1 surround sound. Make sure they are behind the primary listening position. And try them with a 5.1 surround movie. If all speakers are up front switch to front listen mode. Good luck.
Mar 06, 2011 | Vizio VHT510 Theater System
Over the last month or so my T755 has developed blue video noise coming out of the hdmi switcher for high def sources, i know its not the cables or the display because the problem goes away when i take the...
My $.02 for free...
What source(s) are affected? And WHY do you feel compelled to keep the NAD between the source video and the TV, especially if it adds nothing by being there?
Since my TV has a multitude of inputs I run my high-rez video sources only to the TV and high-end audio sources only to my receiver since neither device really benefits from or enhances the other medium.
Feb 08, 2011 | NAD T755 Receiver
The sound coming out of the surround sound speakers sounds like it is under water,but sounds great on 2 channel mode
Surround modes usually process the sound to make it appropriate for the direction from which you'll hear it (ambience, echo, reverb, spatial cues).
Surrounds are not meant to be listened to alone. Does the sound from the surrounds mesh with or enhance the other channels? Perhaps a look in the manual may help, if we knew what electronics we're talking about.
May 19, 2010 | Audio Players & Recorders
How can I reset my NAD T747 to factory defaults?
Restoring your T 747 to its factory defaults: At FM mode, press and hold front panel’s LISTENING MODE button until the VFD shows “Factory Reset”.
Cheers!
Feb 15, 2010 | NAD T761 Receiver
Jan 29, 2009 | NAD T753 Receiver
My Onkyo TX SV 535 Surround Sound wont work
when the stereo or mono listening mode is selected only front speaker and subwoofer produce sound--------make sure that speakers are configured correctly.
and you select surround sound in listening mode.
Aug 17, 2008 | Onkyo TX-SV535 Receiver
Nad c320
If your amp is under warranty, bring it to the nearest service center to have it fixed. But if not, and you know a little electronics, check for the bloated capacitor and/or a burnt resistor on the audio module and replace it. still not working, change the audio I.C. of the amp. If you don't know electronics, bring it to the electronics shop. Audio coming out of the headphone is different form the audio of the speakers. Sounds on your headphone is coming from the preamp circuit. That explains why the headphone audio is ok.
A Simple Thanks is Good Enough
Feb 14, 2008 | NAD C320 2-Channel Amplifier
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
cheekygr1n
Level 1 Expert
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
