SOURCE: need a remote fix for no picture but still have sound for samsung
check if the back lamps are still on when you lose image, all you have
to do is get close to the screen and make is totally black and if is
not that means you have a back light working, but if the back light is
gone you may have a defective panel.
talked to samsung TA about
the same problem I had and the recommend to replace the power supply
first to confirm a defective panel because a panel is quite expensive
SOURCE: My samsung dlp have sound but not picture. I
U put the cover back on,u might of acidently hit the reset protection switch to the lamp module.Check it over,becarefull after the switch back to it proper place.The lamp will light up and work.
SOURCE: Samsung 60" DLP - 6
Hello.
It looks like you ignored lamp replacement in your TV. It have to be replaced every 2.5 years of average use. It's like oil change in a car. Regular scheduled service.
You can read info about lamp replacement in your TV owner's manual, buy lamp on-line and replace it by yourself to save some money.
Regards.
Russ.
Testimonial: "Thank you for the info - wish I had realized about the lamp replacement - should have read the manual I guess."
SOURCE: no picture or sound on 60 inch samsung plasma 550 TV
The power supply regulator board should be checked. Check this link, and select the site named 'Electro-help'. All details are described there in detail.
