HOW to install new capisstor in heat pump - Heating & Cooling
Phkj048-1, what kind of heating equipment do I have?
looks like a heat pump. have you a heat pump tstat? reserving valve wired? setup properly for a heat pump?
Aug 06, 2018 | Heating & Cooling
ICP model #Ch7536vka6 heat pump manual
First, I'm not a ICP representative.
* Repairs on this type of equipment requires a CFR certified tech.
* Check your warranty. Call for service.; http://www.icpusa.com/
*** following is for information only.***
* HVH8 Application Guide (SEER Comparison);https://hvacdirect.com/hvac/pdf/HVH8-App-Guide.pdf
* Parts; https://www.repairclinic.com/Shop-For-Parts/a38b382d1292210/Model-CH7536VKA6-ICP-Heat-Pump-Parts
* Valve parts; https://www.americanhvacparts.com/p-11505-heat-pump-oem-direct-manufacture-replacement-reversing-valve-kit-with-24-volt-240-volt-coils-icp.aspx
* Tempstar 12+ SEER Heat Pump(specs); http://icpindexing.toddsit.com/documents/086477/42821310106.pdf
* 14 SEER brochure; http://icpindexing.toddsit.com/documents/086477/42865600800.pdf
* Digital Thermostat install; http://www.utcccs-cdn.com/hvac/docs/1011/Public/02/61601100600_ICP_5033.pdf
Aloha, ukeboy57
PS: Additional information:
* about heat pumps; https://www.consumerreports.org/cro/heat-pumps/buying-guide/index.htm
* ICP HVAC 5 Speed inverter install; https://www.youtube.com/watch?v=JL4iMH4STzk
* ICP Pinnacle (New); https://www.youtube.com/watch?v=MPkoAZLb6Co
* Carrier VS ICP the same? ; https://www.youtube.com/watch?v=cpnoDiQ3R9I
Jul 21, 2018 | Heating & Cooling
Heat Pump will not shut off
flow switch timer in the unit. its a part on the pcm board. tell the pump to stay on for 10min after heat up. and does other times as well depending on setup... its not really a switch its a chip but it works as a switch.
Mar 08, 2014 | Honeywell Programmable Thermostat Heater
HE heat pump won't talk with old air handler?
The fact is, the air handler supplies the voltage, blower, and electric heat. In order for the heat pump to work correctly, the wiring from the thermostat and heat pump need to be hooked up right to the air handler. The thermostat is what tells which component to come on. If the fan stops, but the condenser keeps going, you either have a faulty fan relay on the air handler, faulty thermostat or wiring, faulty wiring at the heat pump, or the contacts on the new unit are sticking, which is highly doubtful considering it is working now. I hope I have helped you understand this a little more. Good luck and don't let them push you around, get someone that knows what they are looking at.
Jul 18, 2012 | Goodman Heating & Cooling
I have an HRV system and want to know if it is possible to run a heat pump through my HRV ducts in the ceiling?
Hi, can you tell me what kind of heat recovery ventilation system you have? Is it a Honeywell, Lennox, ect.? Also tell me about how you have it set up as far as the duct work you are talking about and what kind of heat pump system you plan to install. If you tie your central air heat-pump ducts into the HRV ducts, it will interfer with the air flow. If you will, please tell me what you plan on doing as far as installing what to your home? New duct work for a new central air heat-pump unit, or what, so I will have some idea on what you are doing. Thanks so much. Contact me through my user name below.
Sincerely,
Shastalaker7
Apr 13, 2010 | Heating & Cooling
I have a new York hybrid heat pump/gas furance
Did they check the sensor in the plenum. You are suppose to have bonnet sensor to switch from heat heat pump to gas whaen it is to cold for the heat pump. The bonnet sensor may be to bad. The unit is cycling ever five minutes because it may have five minute time delay.
Dec 15, 2009 | Honeywell Programmable Thermostat Heater
Trying to install new programmable thermostat.
Standard hook up for Heat pump.
Red wire----------R
Green-------------G
Blue----------------C
Yellow-------------Y
Orange------------O
White--------------W1 with a jumper to E sometimes will also say Aux, varies with Manif. of T-stat.
Hope this helps you out.
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Oct 20, 2009 | GE Zoneline AZ55H09D Air Conditioner
Trouble Installing Hunter Brand Thermostat
on the back of the packaging for the HUNTER MODEL 44155C it states that it is not compatible with heat pumps
Mar 01, 2009 | Honeywell Programmable Thermostat Heater
Wiring diagram to connect programmable Thermo to Heat Pump
I don't know if this will be helpful or not, but I just installed a new Honeywell and the Honeywell customer service guy helped me get the wires done correctly. The number is 800-468-1502.
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
