Don't listen to the idot that said to change your oil at 39 miles! If you only have 39 miles on your bike and your oil light is on it mean there is low oil pressure so you need more oil in it. Cause the only reason that light goes on is when theres not enough oil in it. Not because you need an oil change.Also the oil change should be done at least every 3,000 miles but I do mine at 2,500. Also When you change the oil for the first time, you want to change the Filter as well. Every oil change there after you dont have to change the filter every time, you can do it every other oil change if you choose to. And always fill it up to in between the lines of your sight glass. and always makesure that after you put oil in it you start it up and for about 30-60 seconds then shut off and let sit for about an hour and add oil as needed.
It's better to change oil now
