Refrigerators Logo
Anonymous Posted on Oct 21, 2019
My hisense fridge freezer child lock will not go when I tap on it for 3 seconds as the booklet says so the water and ice will not work
Victor Mosim
Level 2:
New Friend:
  • Expert 95 Answers
  • Posted on Oct 06, 2020
Victor Mosim
Expert
Level 2:
New Friend:
Answers
95
Questions
0
Helped
45835
Points
130
Try to unplug until for 15 minutes
5 Related Answers
Anonymous
  • 143 Answers
  • Posted on Jul 23, 2008
SOURCE: Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Anonymous
  • 311 Answers
  • Posted on Jan 30, 2009
SOURCE: amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Anonymous
  • 1136 Answers
  • Posted on May 30, 2009
SOURCE: water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
Anonymous
  • Posted on Jul 03, 2009
SOURCE: leaking fridge
my maytag had cloged defrost drain cleaned drain all ok
arikrom
911 SERVICE TODAY
  • 528 Answers
  • Posted on Jan 04, 2010
SOURCE: Neff K3990 American style fridge ice maker is not producing ice
The ice maker unit give the command to the water valve to relese water for a short time.
you cna check with volt meter on the water volve that got the pip go to the ice maker unit if it getting 120V for short time when the fingers of the ice maker making full round.
if you get 120v the problem is the valve (the ice maker and the water have difrent water path so its difrent valve used) if you dont get 120v or the fingers of the ice maker not turning then its your ice maker unit need to be replace.
I hope you find this Very Helpful and best regards!
Testimonial: "Many thanks ,will give that a go and come back to you"
Whirlpool Sixth Sense American fridge freezer child lock.
This has already been answered on Fixya. There is also a video and a copy of your manual. Press and hold the Lock button for 3 seconds.
Or
Child Lock (Water / ice dispenser lock) To lock/unlock the water/ice dispenser and related buttons, press the "Ice mode" and "Light" buttons at the same time until the symbol is displayed and the acoustic signal sounds.
SOLVED: Whirlpool 6th sense fridge freezer electronic - Fixya
https://www.fixya.com > support > t24825843-whirlpo...
Nov 14, 2019 - Emma: The lock and unlock feature is accomplished by holding the lock button for 3 seconds, and you will see a count down number just above it that ...
SOLVED: Cannot unlock my whirlpool fridge - Fixya
Nov 19, 2019
unlock whirlpool fridge Questions & Answers (with Pictures)
Nov 21, 2019
How do you put child lock on a whirpool aqua 6th sense.. - Fixya
Mar 6, 2011
Whirlpool 6 sense American fridge freezer child lock - Fixya
Mar 13, 2022
More results from www.fixya.com
People also ask
How do I lock my Whirlpool Sixth Sense refrigerator?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;"> How do you unlock a Whirlpool American fridge freezer?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;"> How do I turn off Child Lock on my fridge?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;"> How does Child Lock work on a fridge?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;"> Feedback
Using the Control Lock Feature - Product Help ' Whirlpool
https://producthelp.whirlpool.com > ... > Tips and Tricks
Jun 15, 2020 - The dispenser can be turned off for easy cleaning or to avoid unintentional dispensing by small children and pets. NOTE: The lock feature does ...
How to use the control lock on your refrigerator - YouTube
https://www.youtube.com > watch
PREVIEW
0:52 How to use the control lock on your refrigerator For additional product tips and troubleshooting please visit ...
YouTube · W Service · Jul 15, 2019
Missing: sense ‎' Must include: sense
QUICK START GUIDE - Whirlpool Docs
https://docs.whirlpool.eu > _doc
PDF
Use this function to chill drinks inside the freezer ... (Sixth Sense Function) ... The "Child Safety", "Key Lock" or "Ice/water dispenser lock".
2answers
Red light
Try firsd doing a complete defrost, leave fridge unplugged at least 24 hours
My Bosh Refrigerator / Freezer water/ice dispenser is in lock mode, how do I unlock it
Most electronic fridges have a child lock facility. Usually, you need to press and hold 2 buttons at the same time for a few seconds until it beeps. Not sure of a Bosch but its usually the temp up and temp down buttons. It should say on the display how to lock / unlock
Whirlpool 6th sense fridge freezer electronic panel - how do i unlock? child lock not on
Emma:
The lock and unlock feature is accomplished by holding the lock button for 3 seconds, and you will see a count down number just above it that indicates 3, then 2, then 1, and a soft tone along with the lock icon appears. To reverse this hold the same button for 3 seconds following the same procedure and the unlock icon will appear.
RT50 control panel not responding
It still sounds like the child lock is on since that prevents accidental setting changes on the refrigerator's control panel.The following will NOT work if the child lock function is activated: Freezer Temp Button Fridge Temp Button Power Freeze Button Power Cool Button Ice Type Button Water Button Ice maker Water OR it may be in Cooling Off/Demo Mode. Cooling Off/Demo Mode is a feature used by retailers to display the refrigerator without running the compressor. If your unit is not cooling, and the bars are constantly scrolling up and down the temperature, check your manual for reset advice
1helpful
Ice dispenser/water dispenser in side by side fridge not working
Your dispenser is child locked. Hold the child lock button for 4 seconds and the key should disappear, if you do not know which key to press I will need the model number from the tag located on inside of the fresh food section top right corner.
2helpful
Bosch intelligent frost free 88
We have the same and I think it is because the freezer door bounces open when we shut the fridge door. Then the freezer compartment ices up, the fan clogs up with ice and cannot blow cold air into the fridge, and the fridge gets warm and the milk goes off.
Solution? We have bought one of those child safety clips (search for fridge safety clip or lock) to hold the freezer door closed.
Simple design error. Expected better from Bosch :-(
1helpful
Ice Maker Hookup for LG side by side with freezer on bottom. We connected the water line to the fridge to the connection in back.... both connections, the one up top and the one on the bottom. We are not...
ok...1st there is only one connection to the fridge at the valve.2nd check the filter and see if one is present.3rd make shure the child lock out feature on the dispencer is not activated.
2helpful
Cant get child lock off
Hold down the ice button and the child lock button together for 3 seconds and that should work.
3helpful
Samsung water filter rs21 dcns
Hold down the "ice type" and "child lock" buttons (bottom button on the left and the right) together for about three seconds. The light will change back to green.
Aug 06, 2008 • Freezers
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
