Question about Samsung Audio Players & Recorders
Samsung home cinema system-FLASHES FRANC HK and then switches off
6ya staff
SOURCE:
Anonymous
SOURCE: Samsung home cinema system HT-THX25 Multiregion hacks
Turn on the HT with no DVD. Press the following buttons on the remote: ENTER 8, 4, 2, 6, 9 ENTER
It will turn off. When turned again on it is a region free HT.
Posted on Nov 26, 2008
Anonymous
  • 7 Answers
SOURCE: no sound through my lg home cinema system when watching tiv
fiirst of all you should buy a converter..........which has a multiple use
Posted on Mar 04, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: SAMSUNG HT-TZ212 home cinema kit comes up with protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
rylee_smith
Rylee Smith
  • 8619 Answers
SOURCE: I need to reset the region code on a samsung home
Hi
Thanks for using FixYa. Please follow this procedure to reset the region code (or to make it region free).
Open tray and remove any disks in tray, then Close the tray. 1. Switch Off Player and Unplug from mains wait 30 seconds (this clears RAM) 2. Reconnect to mains 3. Turn on player with remote. 4. Press ENTER on remote. 5. Press 8, 4, 2, 6, 9. Using keys on remote.if your player is already set to region 2 6. Press ENTER on remote. (The tray will open and player will power off and close tray.) 7. Switch on power from remote. 8. Player is now Region Free. Allows both region 1 & 2 DVD's to play.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 15, 2009
Anonymous
  • 3 Answers
SOURCE: how can i listen to my tv through my cinema system
Use a fiber optic cable
Posted on Dec 27, 2009
Franc hk
Hi the problem is, is that the system is overheating. Meaning the extractor fans inside the machine could be taking in excessive heat from over systems and the machine is trying to turn off before any damage to the system. Solution: Move it to a more open area!
Jul 23, 2012 | Samsung HT-Z310T Theater System
Tring to connect my samsung tv to my samsung home cinema and having problems
Hi,here is my simple solution...
to listen your TV on your Stereo system thru your
samsung home cinema receiver,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on
samsung home cinema RECEIVER corresponding your RCA or Optic connection..
There you go..Your TV sound is on the
samsung home cinema Receiver..By this means whatever you watch on the TV (TV tuner, satellite , Xbox ..etc.) ,it's sound will come thru your stereo..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 25, 2011 | Samsung Audio Players & Recorders
Samsung dvd player switches itself onto protect!
hi,i can't connect my audio tv to cinema theater dvd
Apr 02, 2010 | Televison & Video
Protection Error
maybe the audio amplifier IC´s are in bad conditions and need to be replaced
Jun 30, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Samsung HT-A100 Home Cinema system plays cd only with tv on!
You need to put away the remote for your TV and use only the remote for your HT system. Your HT remote should work on your TV by default. Your Samsung HT remote should have a TV button and a DVD/Receiver button (or HT button). When using only the TV, press the TV button and then use it for just the TV and when using the HT system, press the DVD/Receiver button and then you can use the HT system.
If for some reason your TV is not set on the Samsung HT remote by default, your HT users manual should have a list of codes that you can use to program your HT remote. Hope that helps you. Gary
Mar 18, 2009 | Samsung HT-A100T Theater System
Samsung HT-A100 Home Cinema system remote interferes with tv!
Some remotes have facility for changing frequency to avoid conflict. Check yours out for this feature.
Aug 29, 2017 | Samsung HT-A100T Theater System
Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
Jan 13, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
How to hear sky tv's voice from home cinema system?
PUT A SET OF PHONO CABLES FROM AUDIO OUT ON SKY TO AUX INPUT ON YOUR SAMSUNG.SWITCH SYSTEM TO AUX INPUT SET SOUND 2 PROLOGIC 2,AND HEYPRESTO SURROUND SOUND I HOPE.
HOPE THIS HELPS.
CABLE GUY.
Jun 26, 2008 | Audio Players & Recorders
44 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
