SOURCE: date/time imprint. Coolpix 2100
To remove date imprint. This is the solution provided by Nikon more than a year ago. Switch on> set to green>menu>scroll down to Date Imprint.press centre/right on multi selector>select 'off.' Job done
SOURCE: Canon SD 1000 time and date stamp on downloaded photo
Set the resolution to PostageCard (1600x1200).
Many of these cameras have only ONE RESOLUTION setting which allows you to have a date/ date and time stamp on the file, which will print on the viewed or printed photo.
How to do it:
Turn the camera on M mode.
Use the func. set.
go down the menu to the resolution settings. (on the bottom of menu).
Pick only the postagecard (1600x1200) setting.
I also was like you, and had an awful time with a camera I was fixing. I then looked it up on the Net and found an online user manual for the Canon SD 500, which should be basically the same.
SOURCE: how to make date and time stamp on Nikon d40x
The D40x will not timestamp the image itself.
The date and time are contained in the JPG metadata, which you can access when you look at the picture, or can imprint when getting the pictures processed.
SOURCE: cannot turn date stamp on in menu settings.
Date stamp is only possible when you set the resolution (picture size) at "Postcard 1600x1200" option, if the date stamp is set to "Date & Time" or "Date" option
SOURCE: date time stamp
The camera must be set in the Postcard mode under the resolution setting (L, M1, M2, M3, S, Postcard) on the function menu. Press Function, scroll down to bottom, then scroll to the Postcard mode and press the Set button.
Testimonial: "Fantastic! I've been trying to sort this out for ages, and that has done the trick! Cheers :) "
Firts set the time and date
Go to "Setup" menu
Highlight "Date"
Display DATE menu
change yera. miont, day , hour
left menu
Time and date of recording is included with all pictures
taken with your Nikon digital camera.
try again , take a picture and look if show date time
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
