Question about LG Televison & Video
I don't receive anymore, signals HDMI, on my tv set . LG "47LX6500" not from Orange decodeur, nore. from Chromcast on any of the 4 hdmi plugs Merci
This tv works Well with Antenna and with the DVD, ,but nothing via the hdmi plugs,.
6ya staff
SOURCE:
Anonymous
SOURCE: Unable to get HDMI signal into TV
In the setup guide, try going to the HDMI option where you turn the montior out to "on" for the HDMI output. I don't believe that the receiver comes with the HDMI out already turned on...
Posted on Jan 01, 2008
Anonymous
  • 472 Answers
SOURCE: BenQ FP241W 24" inch problem with HDMI connection
Sounds like the HDMI port on the monitor has been shorted out.
There are very small fuses on the video board that can be changed, but they are fiddly and you may end up doing more harm then good if you are not sure what your doing.
The fuses are actually soldered to the board...it's not a case of pop one out and pop one in like the glass type.
Hope it helps =)
Posted on Apr 09, 2008
Anonymous
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
This might somewhat help. Today I went back .. I went HDMI out of the Cable box and DVD player into 2 of the TVs HDMI ins. The digital audio out from each, straight to the receiver and things are working ok. All speakers are working OK. Sound isnt as loud or crisp but unfortunately I found no other solution.
Posted on Jan 06, 2009
Anonymous
  • 520 Answers
SOURCE: connecting asus notebook via hdmi to LG 42 plasma tv
best option to use s-video lead ...use fn + f-key that has little square printed on it ...hp mostly fn+f4
Posted on Feb 12, 2009
Anonymous
  • 4 Answers
SOURCE: No signal input when connecting PC to LG TV via HDMI
Do you also have a computer monitor attached to the computer when attempting to use the HDMI?
Posted on Mar 30, 2009
I have bought a LG TV model 47LX6500 three years ago and suddently all (4No) HDMI ports are not working.
mainboard issue try updating first
if nothing happens try factory settings and after that replace mainboard or hd controller on you current mainboard
May 19, 2014 | LG 55 55LW5600 3D LCD TV
Why won't my Toshiba Satellite L655 laptop connect trough HDMI anymore?
Check your settings,both bios and display,for the display priority.Either the settings has been set to inbuilt display and thus cant display on external monitors or the external monitors have been disconnected in bios settings
May 15, 2014 | Toshiba Satellite L655-S5101 Laptop
No signal from HDMI mode when I switch on the TV
HDMI is an input to the TV not an output. You select the appropriate input e.g hdmi 1, hdmi 2 on the remote. There can be a return signal the other way but the cable has to support that. Try a different hdmi cable.
May 14, 2014 | LG 42LE5500 42 in. TV
No signal from hdmi for LG TV (lg47lm7600).
Looking around I find that LG is known for this type of break. Unplug TV for 30-45 min, plug back in. The key is to discharge TV by doing so. I would bet that this is a design flaw or hardware anomaly. If this is the case, buy another TV and expect to get 4 years max out of it... Crappy manufacturing and design is most likely the culprit.
May 07, 2014 | LG 47LM7600 47" 3-D LED TV
TV was not in use but storm came through this morning and we were without power for 2 hours. Now when I turn the TV on it is not receiving a signal through any of the 4 HDMI ports. Cables work ok,...
Processor could be locked up, unplug the set from the wall for 40 Min. and that reset it back to normal. If that don't work, than it will need repair.
Aug 23, 2011 | LG 42LH40 LCD TV
I have all proper 3d equipment, cant get the damn glasses to work, lg led 3d tv, hdmi cables, ps3 as my blu ray player, and ps-100 lg 3d glasses....wont synch with tv and im sooo freakin frustrated!!!!
make sure the left right buttond on remote are set right or it looks like glasses are not working it is the blue button i think, i have the lg 47lx6500 and i had the same thing happen to me.
Feb 12, 2011 | LG Televison & Video
HT762TZ -hdmi off
Try new hdmi cable. Try different inpus on set. Try another known good signal source to determine is tv or souce device if at fault. If aother hdmi connector on set ok then replace main brd in tv, if none of the hdmi inputs work even with known good cable and known good signal sourse the replace main board in tv
Aug 29, 2009 | Panasonic DMR-EH57 HDD Recorder Player
No HDMI video output from AVR-588 receiver to plasma TV ???
the avr-588 apparently cannot carry sound via hdmi - don't know why; just what i found out from the geek squad at best buy; solved the problem by connecting optical cable from cable box to receiver; be sure to change the input on the receiver for opt-2 (system setup >2 inputs) to correlate with tv
Feb 16, 2008 | Denon AVR588 Receiver
Televison & Video Logo
18 people viewed this question
Ekse
RONALD CARTER JR
