Download Cleaning app from playstore and scan your phone after that boost it done...
check out our latest fashion products at : Chilker
visite : https://chilker.com/product-category/saree/
If your Sam4 ER-390M cash register is displaying a "Warning Power Fail" message, it means that the register has detected a power outage or an interruption in the power supply. Here are some steps you can take to fix this issue:
Check the power supply: Ensure that the cash register is properly plugged into a working power outlet. If the power supply is shared with other devices, make sure that they are not causing any power surges or fluctuations.
Check the battery backup: The Sam4 ER-390M cash register comes with a built-in battery backup that can keep the machine running in case of a power outage. Check the battery backup to see if it is functioning correctly. If the battery backup is not working, it may need to be replaced.
Reset the cash register: Turn off the cash register, unplug it from the power source, and wait for a few minutes. Then, plug it back in and turn it on. This will reset the cash register and may resolve the issue.
Contact customer support: If none of the above steps work, you should contact Sam4 customer support for assistance. They can provide further guidance on how to resolve the issue.
It's worth noting that if you experience frequent power outages or power supply fluctuations, it can cause problems with the cash register's electronic components. In such cases, you may need to consider using a voltage stabilizer or a UPS (Uninterruptible Power Supply) to protect your cash register and other electronic equipment.
Contact the maker/dealer direct for a new display. If you are good with a soldering iron, strip it down and look for a blown capacitor on the back of the display board.
I haven't replaced one on the 650 as I've never seen one fail. They are very reliable so make sure the printer is actually faulty before ordering one. Usually easy to replace. Just one connector on most.
Mar 8, 2005 - This manual is subject to change without notice and CRS, Inc. has no ...Check with your local solid waste officials for details concerning recycling options or proper .... Function Key Definitions . ...... Get Gift Card Balance .
electronicbiz.com > Point of Sale Systems > Cash Registers
With 150 key locations, the fl at, spill-resistant keyboard can easily ... Where menuschange daily with breakfast, lunch or dinner times the paper key-sheet under the overlay is ... A simplifi ed check tracking feature is available for bars and cafes. ... The ER-900 Series is electronic payment and gift card processing ready - no ...
May 1, 2008 - You will not find an easier cash register to program then the ER-650 or ER-650R register. .... i have er 650 and I tried to change my function key and change.... Don't forget if to check here is you need a new NEW SAM4s Cash Register ...... OK you can add a payment type and a new PLU to sell the gift cards ...
May 1, 2008 - I really like the SAM4s ER-650 Cash Register and ER-650R Cash Register. ... By the way the SAM4s ER-650 and ER-650R is the same as the Samsung ER-650 and ... I can't seem to figure out how to program it to track ticket/check #'s. .....also, neither the Reg Key or Mode Key will turn to SM mode. help?
If not, you will need to go to the SM mode and configure either RS-232 port 1 or port 2... Press enter (cash key) through the rest of the options. ... I could not get the curserinto the plu numeric field once i entered the plu. .... There are manuals for the SAM4s ER-650 at http://www.cashregisterguys.com and if you are looking for ...
Those machines have a memory allocation section where you need to define the file sizes for products, etc. If your file size is smaller than the machine you are copying from, then it wont work. Try setting the memory allocation first.
