I have a enerstat dsp-600 gone bad is there another brand I can use want to go programmable
Robertshaw 9520 no power
I do not have a clue what you are asking but go to the following link and read the manual.
http://www.enerstat.com.au/robertshaw9520.pdf
Dec 08, 2013 | Electrical Supplies
Thermostat help!
Add a comment with Brand, model, and type of appliance. This will help locate product manual and resources.
Otherwise, you could have Bosch tankless water heater that needs to be delimed, or maintained, flame rods are bad or dirty, or PC board has gone bad etc
http://hometips.me/Tls/Bosch_EA_error_code_troubleshooting.pdf
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html#delime
Add comment
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 24, 2013 | Honeywell Rth6350 5-2 Programmable...
Hi my amp when i switch it on within 3 seconds it automatically switches off?
HI...
That's the protect circuit kicking in.
The rec'r will require service. Either a couple of power supply capacitors have gone bad or one of the power amp modules has quit.
Nov 02, 2010 | Yamaha DSP-AX1 10-Channel Amplifier
I need to get 2 slates for y600 pizza ovens do you sale them.
When your looking for this part it is called the "Stone Deck"
36" X 60" for most Y600 Models. FixYa is a "help you" site not a full blown retail outlet.
This is the Y-600-(old style) manual:
http://www.bakerspride.com/pdfs/Y-600%20Parts%20List%20OLD%20STYLE%207-05.pdf
This is the Y-600 manual: http://www.bakerspride.com/pdfs/PartList/Y-600%20Parts%20List%20U6050A%208-08.pdf
This is the Y-600-DSP manual:
http://www.bakerspride.com/pdfs/Y-600%20DSP%20%20Parts%20List%20U6051A%202-07.pdf
Their website went down for maintenance as I was doing this. But their phone number is on the website. http://www.bakerspride.com/
Thier manuals list is here. Note the price list for parts is at the very bottom block top of 3rd row.
http://www.bakerspride.com/manuals.asp
Thanks for choosing FixYa.
Kelly
Sep 14, 2010 | Bakers Pride Y-600 Gas Single Oven
I have a brand new PB desktop pc - only 3 days old - when I open it up it works fine but once I have gone into a programme and closed it the desktop freezes - I can open other programmes from the start...
If only 3 days old, get in touch with the shop you got it from, or the support line.
You dont want to be messing about with system restore/recovery on a brand new PC
Aug 05, 2010 | Computers & Internet
The relay switch clicks but does not power up my yamaha emx300 pa amp/mixer.
I have one like it in my shop
The main power transformer has gone bad
Yamaha has them in stock
Aug 04, 2010 | Yamaha DSP-AX1 10-Channel Amplifier
On any channel I've begun to get a intermittant
If this has a digital effects processor read on.., I had a SIMILAR problem on a Behringer GX110.
The electrolytic filter cap for the 5 volts of the DSP effects had gone bad. The 5 volts was dipping when the DSP reset and it would repeatedly reset causing a clicking at about once a second. 50 cent part fixed it. The part is a little undersized electrically so is more prone to failure in the unit I have.
That particular one had the DSP as a seperate board with its own 5 volt supply from the main transformer.
Dec 18, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Programmable A/C thermostat has power but shows no temp.
Check power totast. Float switch sometomes kills power to stat. Check drain.
Jun 08, 2009 | Heating & Cooling
HTR-5240 Will not play audio when switching to DSP
Most likely your DSP board is bad, usually a pretty costly repair and sometimes the board is hard to find in stock.
DSP--Digital Signal Processor
Dec 01, 2007 | Yamaha HTR-5240 Receiver
Tx-ds777
Same thing happened to our TX-DS777.
Took it to a locate electronic comany and they told us it was the
DSP board gone bad. Est 425.00 to 450.00 to fix.
Aug 16, 2007 | Onkyo TX-DS777
 Grubhead
Grubhead
Marvin
Marvin
